Installing aftermarket LED's as fog lights?
Isaiah W
Hey guys, so I bought these LED lights on Amazon https://www.amazon.com/gp/product/B00DR67P9I/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 and I was wondering how I could hook them up to the factory wiring for the existing fog lights? The LED light only comes with a red and black wire, what do you suggest is the best way? I've thought about getting an adapter like this https://www.amazon.com/Headlight-Bu...699271&sr=1-2&keywords=male+headlight+harness but I'm not sure if that would work? If it would work, do I have the right plugs to plug into the factory wiring for fog lights? Let me know if I need to explain anything, thanks for your help!
Note: 2002 Tahoe LS
05Single
afraid of the dark
That will work. Your bulb is a 880 so I'm not sure if a h11 base is the same, but it looks just like it.
BigDaddy13440
Rome, NY
They will work fine. I have a set of double row on mine, with the clip-on amber plexi covers. I just cut the factory connector off, and wired them up. Capped them with wire nuts, and wrapped them in multiple wraps of electrical tape.
Mine are 12 LED 3w bulbs, so 36watts each. Awful damn bright, I must say.
And then I've got a 32" curved bar with 60 LED 5w bulbs mounted in my grille.
mmeachem
Any pics of the fogs and mounting etc
BigDaddy13440
Rome, NY
veteran111
