2013 Tahoe Performance upgrade tips
BigM
good day all, this is my first time here :)
I just got myself a 2013 Tahoe z71 and would like to do some performance upgrades to gain some power, acceleration, sound...etc. nothing fancy or expensive but I've read some posts here and might be interested in:
1- Headers: brand/type, long/short tubes...
2- Exhaust: full, single/double tip and which brands best? I've tried borla before...
3- Air intake?
I appreciate the feed back on the above :)
TIA
massivespl
I'm not mean, I'm honest.
Michigan
Muffler for sound - $150
Cold air intake off eBay-$80
Truck will sound mean for cheap.
Then get a nice black bear tune. $$$$
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Or if you want quality parts search the classified section. People selling
Intakes and exhaust all the time. In addition to muffler, cut off the resonator and install a exkaust tip at the end.
Do yourself. Favor too, when you get a tune like black bear or so, have them disable the AFM. Saves so much more hassles and rids the oil consumption problem
BigM
BigM
Thanks for the info but if I'm to install headers what you suggest? Long or short tubes, with stock exhaust or if to add exhaust which brand/type would fit the Tahoe?
As for the BB tune I'm definitely getting one; any special type/model?
Excuse my questions I'm just new to Tahoes :)
3- Air intake?
TIA
1- Longtubes with 1.75" or larger primaries. Short tube headers in this application are really just for show and so you can say that you have headers. Get the best you can afford as this is a "you-get-what-you-pay-for" thing. I've heard and read a lot of good reviews on the longtubes from Speed Engineering. Bolt-in package with Y-pipe is around $350. While installing the headers is a good time to install new engine mounts if they're original.
2- Cat-back is fine at this level. Stay with stock size piping (2.75") or one step larger (3"). I'd leave the stock piping in place if it's in good shape and just have a muffler welded in. There are countless muffler options, you just have to read up on reviews and listen to sound clips to decide what you want. Generally, any turbo-style muffler will be fine as far as performance. It's the size of the muffler and the amount of packing around it that will determine the exhaust note and volume.
3- The stock air filter and box is fine. It's already sealed off from the heat of the engine bay as well as or better than any expensive aftermarket air box would be and the filter is capable of flowing more CFM than the engine can inhale. The restriction (although minimal) is the muffled tubing between the air box and the throttle body. You can cobble yourself together a straight and smooth intake with PVC pipe and fittings and silicone couplings from eBay (cheapest option) or buy a pre-made tube such as the Airaid MIT (easiest and cleanest option). The $150 MIT has been shown to equal or beat the full intake setups costing twice as much.
Between a free-flow intake tube and exhaust, you will notice a more powerful sound and more power in the mid- and upper-RPM ranges. After all mods are complete, get a Blackbear tune to compliment them. I agree with having the AFM disabled. That 1 MPG (at most) you MAY sacrifice will be more than compensated for by saving you the cost of oil to keep it topped off between changes.
sumo
rhode island
Don't bother with shorts. You won't gain anything but sound. For headers, I run American Racing headers 1 7/8. I run bigger because I'm Supercharged. Better flow for me. When Researching i discussed with Blackbear that 1 3/4 for NA and 1 7/8 for forced induction. Going larger you could lose in some bottom end but will gain in top end. Not a problem for superchargers but in a NA i wouldn't want to sacrifice anything on the low end.
When it comes to Headers you'd want to get stainless. Stay away from Ebay junk. I When researching headers i also looked into Fitment issues and others reviews of headers. I had a few kinks but easily fixed by repositioning clamps.
Heres a link to the ARH on my build
http://www.tahoeyukonforum.com/threads/supercharged-tahoe-tbss.81587/page-5
BigM
BigM
Thanks a lot guys that was useful
So: 1.75" long tube SS headers, cat-back with stock piping for exhaust with mufflers (any specific brand?) and Airaid MIT and ofcours BB tune with AFM disabled. :Big Laugh:
Will see with these mods. I might get more excited and add a supercharger later!!
sumo
rhode island
I'm running magnaflow muffler no resonator stock cat back piping which is 2.75 with Arh 1 7/8 headers. If you seen my videos my truck is pretty dam loud. No point for me to spend the money to change piping to 3 inch. I won't get any more gains out of it other than making it louder. Let me see ifni can find some vids of just the magnflow and resonator delete before sc install
Found them. This is with a bb tune and volant enclosed intake
BigM
BigM
Wow that's awesome :favorites37:
So the mufflers with no resonator is mainly for sound? Or it has effect on performance/gain?
And btw are those 22" rims? What tire size?
Meccanoble
Georgia
Just curious how much the tune is? If you plan to get tune, the catch can is not needed right? What if you get a tune with just 1 mod added (intake) and later get exhaust, will a new tune be needed? Can the tune ever be removed?
Meccanoble
Georgia
Also, someone mentioned the stock airbox for intake is more than plenty. Only restriction is the tubing from box to throttle body. Buying an ebay kit just to use that part and keeping everything else stock would be fine? Anyone try to fit a better filter (cone like) into the stock airbox?
Ebay kit = $60ish
Quality filter = 60ish?
The catch can has nothing to do with a tune. It's to filter the oil mist from the air inside the engine and store it in a can so that it doesn't get sucked back into the engine. A tune is reprogramming the fuel and ignition tables in the PCM to optimize performance, whether it be for a stock or modified engine. Other functions such as transmission shifting can be changed as well. If you want a tune, you should wait until you have all of your bolt-on mods completed so that the PCM can be tuned to optimize performance for all of the mods. You can always have a custom tune modified or removed and the stock tuning returned to the PCM.
Ebay kit = $60ish
Changing the stock filter to a cone style isn't worth the effort. The stock filter flows more CFM than what the engine can pull in while effectively cleaning the air. An aftermarket filter may or may not filter as well- why risk it? If you're looking to spend $120 on the intake ($60 eBay kit and $60 filter), you should just get an Airaid MIT and be done with it: Far less work, proven gains, no compromises.
Meccanoble
Georgia
Thanks for recommendation. I found the tube you referring to. So get stock filter since I will see little to no improvement going with different filter and just get upgraded tube (http://www.airaid.com/search/product.aspx?prod=200-996)
I had high powered 6 cylinder cars that were quoted to get improvement with just filter (hard to believe). Partnering a cone filter with this setup will only help with sound, not power? Was hoping my first 8 cylinder would see the most improvement of all the cars i had with simple intake....
This intake is about as simple as you can get. The gain is had by removing all the mufflers that the stock intake tube has. No muffler chambers=smooth and direct path for air flow. You will get a nice sound (very similar to a mild performance muffler) with just the intake tube (the Airaid MIT). This deep and throaty sound is exactly for what the GM engineers added all those mufflers to quiet down. You can use a stock-replacement drop-in filter if it makes you feel better. I recommend a non-oiled one such as an AEM DryFlow. But there's no reason to redesign the whole setup unless you're just bored and have time and want to create another perpetual maintenance item.
BigM
BigM
Will this go with 2013 z71 Tahoe 5.3?
I'm still in the process of getting the headers and exhaust system procured. :favorites37:
BigM
BigM
IMG_9483.JPG i came across these long tube SS headers, from kooks 1 3/4" x 3" any feedback on gain, installation...etc. and will it fit my Tahoe directly or requires any modifications? (A bit expensive though!!)
and also what's your thoughts on the Range AFM disabler?
Hope the picture are clear! :)
Meccanoble
Georgia
On my previous M3, the tube was the recommended change to improve power through flow like you said. There were also these scoops that helps push air into the intake but still question if they helped. Regarding filter, the link someone sent shows AC Delco being pretty good. I guess an aftermarket dry flow filter is more ideal for someone that wants to change their filter less frequently? Assuming stock needs to be changed around 15k vs these more expensive ones every 30-50k?
My opinion is that the cheaper aftermarket ones don't filter as well so they take longer to get dirty. Also, most of the aftermarket "performance" filters are washable/reusable, so there is no "changing". Honestly, I don't replace my filter by mileage. I inspect it every other oil change and blow it out in the reverse of normal flow with my compressor. If it's too "permanently grey", then I'll replace it. I'm currently running an AEM DryFlow just because I got it for the cost of shipping. A few weeks later I ended up with an Airaid MIT. It's my weekend car so I won't be inspecting the inside of the Airaid for passed dirt for a while.
Meccanoble
Georgia
Well they werent cheaper, they were more $ but they were oil based filters similar to K&N but better rep. I forget name (B&M or something) but I remember paying 90 for one and it didnt need to be cleaned for longer than the stock one along with supposed gains. They were better recommended because the quality of frame of filter and they didnt over oil which is probably #1 cause of MAF's going bad. But I'll end up doing what you do.
johnsonwillie199
