Is there 12v at the main connector?No luck after either. I must've missed a connection or something because it has to be highly unlikely that both were working before and aren't now.
Were they both working before? If so, I'd think it was a fuse. Odds of them both quitting are slim. Also disconnect and reconnect the wires.Finally got the leather seat covers replaced and installed in the truck. Neither of the power seats are working though. Everything is connected, so I'm not sure what has happened. Any suggestions?
I put my "lift kit" in today.
The keys, which I thought were gonna be a *****, came out easy. I didn't bother with a sledge, I went straight to the jack hammer. Both sides were in and out in under 20 minutes.
And the rear springs, which I thought were gonna be easy, gave me the most trouble. I didn't have a spring compressor, so getting the Z71 springs and 1.5" spacers in was a PITA.
Love the way the truck sits now. It feels like a truck, and not some soccer mom shuttle.
Next step, sway bar end links, and new wheels and tires.![]()
Pics will have to wait. Shes back in the garage, and honestly, I'm too damn tired to go back out there. Haha.PICS, DAMMIT!!!! LOLs!
Yep, both worked before.Were they both working before? If so, I'd think it was a fuse. Odds of them both quitting are slim. Also disconnect and reconnect the wires.
yepIs there 12v at the main connector?
Sent from my SM-N920V using Tapatalk
Okay so that tells me whatever happened is inside the seat harness. Check for power to and from the switch.
And don't forget the other half of the equation- ground. Power does no good without ground!Okay so that tells me whatever happened is inside the seat harness. Check for power to and from the switch.
Where would the seat ground?And don't forget the other half of the equation- ground. Power does no good without ground!
Most likely in the harness along with power. I doubt they would rely on the bolts holding the seat to the vehicle and then ground to the seat frame but it's possible.Where would the seat ground?
Did you black out the "TAHOE" on the rear hatch? I'm thinking of doing that on my doors with plastidip .Can't remove it because it was painted before and they taped around it.Got the rear hatch handle changed. I will try to get the others installed tonight.
Yea that too. I assumed by checking for power one would check the ground in the connector. But forget not everyone thinks the same as me.And don't forget the other half of the equation- ground. Power does no good without ground!
