Gonna be towing soon
popo8
In 13 days I will be taking a road trip to the LTX SHOOTOUT. I will be borrowing a friends 26' trailer to haul my TA down...
Im no stranger to towinf, however I have not done it with my 2002 AWD 6.0 esky yet .
The truck has been lowered, however still has the air ride functioning in the rear. Im assuming when I hook up to the trailer that will sense the extra weight and lift the caddys ass back up as if it were normal height.
Am I missing anything? Is there anything I should know about towing with a lowered esky on 22s.
Btw...its 1500miles round trip...
LTXtech.com IS my drug...
OWNER/ADMIN
popo8
popo8
This is the trailer.
OWNER/ADMIN
Ridculous
Tulsa OK
No issues towing with 22's but I am at stock height with my denali xl. You going over any mountains or steep hulls on your trip.
popo8
popo8
Yes. Have some pretty big mountains to climp at the other end of PA.
OWNER/ADMIN
Ridculous
Tulsa OK
My recommendation is to take it slow and stay in the right lane. Before I had my 408 the fastest I could pull my 7000 lb trailer with the stock 6.0 liter up eishower pass in Colorado (10000 feet above sea level I think) was 30 MPH.
Also do you trailer brakes on the trailer? If not I would recommend it
gat0r
DFW
weight of trailer w/ car?
since you are so low & level... you may want to look into helper air bags for the coil springs.
make sure trailer sits level to ground...what size riser hitch do you have?
i just towed a friends boat... 5500#s (tralier & boat)
i used a 2" rise hitch.
i leveled the rear w/ norcal's kit. so it is ~1" over front.
with trailer on, i was 1 " lower than front on rear air ride
popo8
popo8
Yes... im all set up with trailer brake controller
OWNER/ADMIN
popo8
popo8
The caddy has the air ride leveling system in the rear.
Idk the weight at all.
When u say riser, u mean the opposite of a drop hitch, right?
OWNER/ADMIN
adventurenali92
Big Bear Lake, ca
Like @gat0r said you can get helper bags for the coils. They work in addition to your air ride system and will tremendously improve ride quality while towing that big trailer. I've seen them online for good prices and from,ehat I've seen in some other threads they are fairly easy to install.
popo8
popo8
Do u have any links for these helper bags or any write ups on here about em?
The current owner uses a ram 1500 to pull the same trailer btw. (As far as power goes ).
OWNER/ADMIN
popo8
popo8
Im gonna measure the hirch height and see how much of a riser I need. Then Ill go pick one up. Then Ill go get the trailer and bring it home empty. The car will then be loaded and ill see where we are at. After all I have 12 whole days still. Lol
OWNER/ADMIN
adventurenali92
Big Bear Lake, ca
Mcgaughys makes a kit for lowered suvs. The one I just pulled up for my 2006 Denali XL runs 137. Plus shipping id assume. That's cheap. Looks easy to install. I'll see if I can find a write up on it on here. The one i found was over on tahoeforum.com.
popo8
popo8
And the truck itself should have no issues with pulling the weight.
OWNER/ADMIN
gat0r
DFW
yes, riser -opposite of a drop hitch... most can just be flipped, but not all
firestone & air rite have inexpensive kits avail
i recall seeing some on sdtrucksprings.com site. no drill kits... like 80-150 for kit.
popo8
popo8
Im gonna see if there is am issue once everythimg is loaded. Im pretty sure i can manipulate it by where the car sits in the trailer.
OWNER/ADMIN
mrpep
It doesn't hurt to put a weight distribution hitch either if your trailer weighs more than 2500lbs is what I've heard is recommended. The hitch might add relief to your rear suspension by putting some to the front axles.
popo8
popo8
Ok. Just found the trailer was putchased with the bars but they were never installed. So the mounting points were never drilled into the trailer "neck" because they never needed em and they have used it alot.
This is a pic of the trailer on their 1500, loaded.
OWNER/ADMIN
JamesinAbilene
