How can I increase my 2002 Tahoe 4WD LT's Fuel Economy???
xFuZzYx
IASCA Car Audio World Champion
So at the moment I drive a 2002 4WD Tahoe LT with 234k-ish miles on it. My current modifications list that could have some kind of impact on my fuel economy includes:
- 6" Rough Country suspension lift.
- 20x14 XD Riot wheels with 35/12.50r20 Federal M/T Tires.
- 2.5" straight pipe cat back exhaust (stock cats, I just replaced my muffler with a Y-pipe to 2 4"x18" Exhaust tips.
- I also have like 600+ lbs of Audio equipment in the back of my truck.
I just recently had my spark plugs and spark plug wires replaces less than 2k miles ago and even after that I average 9 mpg around town and 11.5 mpg on the highway. What are some modifications that I could make to my truck to help increase my fuel economy as i travel the country going to professional car audio competitions. I'm open to any suggestions as long as they are not, "take out the extra weight from the audio equipment" or "get rid of your M/T's for street tires" or "put on smaller wheels/tires" or "take out your lift kit" and etc...
Here is a couple of pics just for reference. The 3rd pic is before the new exhaust work was done.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Easy throttle from stops, keep highway speeds to 65. Being lifted you have a higher resistance so your going to have to curb those rpms.
drakon543
Thats alot of rubber your turning. I didnt notice in your mods that you had your truck regeared. If you haven't had the rear regeared with 35s id have 4.56 put in to help lower your rpms as sumo mentioned.
treehan77
TYF Fiend
Crestview, FL
seems obvious, but you didn't mention: have you changed the air filter. clean throttle body? change to electric fans.
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Buy a second car. A Prius like I did. Drive the truck when you want to. Drive the ecobox to work and back every day.
I'm on 35's with a 6" lift and no audio gear and get maybe 11 mpg and 9 city. I love my truck but it's not economical by any means.
xFuZzYx
xFuZzYx
I generally dont go over 2.5k rpms unless im passing someone or im taking off from a dead stop with a hurry, otherwise I take my time when I drive.
What are the stock gears? and is 4.56 the best option to change to? How much power would I loose and what sort of fuel economy would I gain from switching to that gearing? Some shows require me to drive through the mountains and I don't want to sacrifice too much power for only a minimal fuel economy gain. Lastly, how much would doing this cost start to finish?
I planned on installing a K&N CAI here shortly but I didnt know how much power and/or fuel economy I would increase, I wanted to make sure it would be worth the money. and how much of a change would switching to electric fans make? how much do they cost to buy them and have them installed start to finish?
Trust me, I have another Tahoe thats a 2004 4WD LT and a 1993 single cab 2WD toyota pickup. The Toyota pickup is my daily driver when i need some better fuel economy, but sense I still drive my tahoe all over the country for the car audio competitions I need to do everything I can to make these trips not take up as much gas lol.
drakon543
Going to a 4:56 will actually give you some of the power back you might not have even noticed you lost. I think someone posted the chart on a different thread. Its 2:30 am so im not going to look for it right now. Stock i think is 3.53 or 3.73 for you with a stock tire size of 245 75 and your essentially running a 305 or in metric you went from a 29 to a 35 in. You should increase your gearing and it will help your engine spin those tires easier so its not working so hard.
xFuZzYx
xFuZzYx
So going to 4.56 gears will increase the power and the fuel economy at the same time???
drakon543
If i can find the chart today ill post it up for you. If your truck still has the stock gears in it the engine has to work harder to maintain the same speeds as it would with the stock tire size. Which in turn will cause the engine to burn more fuel. If i can find the chart or if someone else has it and will post it there is an optimal gearing for what tire size. Go too high and you will gain only power go to low and the engine has to work harder.
mizzouguy
Lake of the Ozarks, MO
Gears will make the most dramatic difference, e-fans will help a little but its a lot of work and money for minimal gain. Unless your fan clutch is bad i would not bother. When I had a k&n intake i didnt notice any difference in mpg, it just looked cool and didnt require me to be buying new filters ever again. New O2 sensors with that kind of mileage will likely help, i can't believe they made it that long. Is the converter getting clogged? Other than running some fuel system cleaner through and going light on the pedal im out of ideas.
06_2WD_Z71
To find out what gear ratio your truck came with, check the RPO sticker in the glovebox and look for the following codes:
GT4 Rear axle, 3.73 ratio
GT5 Rear axle, 4.10 ratio
GU5 Rear axle, 3.23 ratio
GU6 Rear axle, 3.42 ratio
If you don't have enough gear, one thing you'll notice is the transmission dropping out of OD on the highway on any sort or grade or headwind. When that happens the back and forth is hurting your mileage.
My truck came with the horrible 3.23 gear. With stock tires it was bad. On our family vacation loaded down with gear it was dropping out of OD all the time. With 34" tires it was even worse. It was a pig and always seemed to be struggling in the wrong gear. I put in 4.10s, and the truck now does everything effortlessly without messing with the gear lever. I might should have gone with 4.30s, but so far 4.10s seem just about right for me.
If you have 4.10s or even 3.73s, it might not be worth the money to swap if the truck seems like it is running ok.
xFuZzYx
xFuZzYx
I saw the GT4 on that sticker, so that means that I have 3.73 gears, right? Sense im running 35x12.50's on 20x14's (an extremely heavy tire combo, each of my wheels weigh more than my friends 38x13.50's on his factory 17" wheels) and I always have at least 600+ lbs of audio gear in my truck that stays in there plus whatever else I pack for my trips, what do you think would be the best gear ratio for me to get the best gas mileage that I can while still maintaining some power?
TheAutumnWind
You aren't going to get much better mileage than that. Gears, fans, and tune, plus basic maintenance stuff will help though.
My slightly lowered stock denali on stock wheels averages like 13mpg...
xFuZzYx
xFuZzYx
At this point any increase is worth it. I usually try to go on like 1 road trip a month and some of these trips are 1 day trips where I'll drive anywhere from 100 to 500 miles in 1 day. And if I go on a full weekend trip I'll drive anywhere from 300 to 1600 miles in like 3 days. So whenever I'm taking these longer drives, if I can save a good bit of money on gas then it's completely worth any increase to me.
massivespl
I'm not mean, I'm honest.
Michigan
In my 2002 Tahoe,When I went to slamology this year towing a 4000lb+ Chevy HHR and my truck with 4 alternators and 26" rims I was getting 12mpg on they way there and about 15mpg on the way back because it was more down hill on the way back. I was very pleased with the MPG while towing. I just have cheap eBay cold air intake with an as seen on TV tornado in the intake lmao
Red Rider
i did some reading when i first got my stock truck. But people always post mods claiming amazing advantages, but never back it up with proof. It would be nice to do a test with each mod. and do dyno test before and after.
TheAutumnWind
It would be nice. dyno runs aren't free though.
That being said there is tons of dyno proven mods for the LS engines.
TheAutumnWind
long tubes might be worth considering.
08HoeCD
Suggest that you look at all options, and their costs, then determine how much fuel-cost you can truly expect to save per option, then choose accordingly.
Sounds simple, but many of us will find that the cost of the fuel-saving option exceeds the actual cost of fuel saved.
Eickybobby5050
