05Single
afraid of the dark
- Joined
- Feb 26, 2015
- Posts
- 8,183
- Reaction score
- 11,449
Cop was probably a Ford owner.
Def was! He couldn't appreciate my nice Chevy.Cop was probably a Ford owner.
If your taillights are cop magnets, then my stock Tahoe tails are, too.
Unless you have those LED bulbs with crappy output that you can barely tell the difference in brightness between running and braking lights.
No leds back there, like you said they have lousey output. I don't know what these are called, but they have pretty decent output. You can tell when I'm stepping on the brakes.View attachment 210953 View attachment 210954
Only led is my reverse bulbs.I believe he was referring to the tail light housings, not the bulbs themselves. To wit, he's correct. Most aftermarket head, turn, and tail light housing manufactures don't manufacture them to DOT/SAE specs and therefore can't bare the markings.
See that little diode at the bottom of them that's attached to a circuit board? That tells me that's an LED array bulb.
These all light up white. I have no idea what they're called. Array led?View attachment 211051
I originally had regular led bulbs for brake lights snd they SUCKED! When the brakes were applied you couldn't even tell.
Damn that sounds sweet!They work great. View attachment 80054 View attachment 80055And for a little extra insurance, I grabbed some fiberglass heat shields. Rated far higher then the headers will ever see. View attachment 80056
Running great now. On my way to get the mbrp installed. View attachment 80057 View attachment 80058
Keeping the stock tailpipe for now.Sounds really good.
Thx.Damn that sounds sweet!
Damn that sounds insane!
