W8TVI
Traverse City, MI
I moved my Yukon XL out of the way so I could install the new lights on my dad's Sierra:
Old light :20170525_205726.jpg
New lights :
Bottom light is just like mine, but the CHMSL is hook up to the trailer light wires.
It has 11 LEDs. The center LED and the two on the ends glow for parking lights, and the four in between on each side are the receptive brake/turn lights.
No one will be able to say they couldn't see his lights... :D
05Single
afraid of the dark
Old light :View attachment 82525
New lights :
View attachment 82523 View attachment 82524
Nice and bright ! Just how I like it!
Need to find your dad a fiberglass cm topper.
jaywoo65
Cabot, AR
Replaced my climate control. On the old one, the driver's side temp knob didn't work worth a crap. Didn't matter how you spun it, it wouldn't control the temperature correctly. It had a couple burned out bulbs also. The new one I found on EBay. Blue LEDs to match the instrument gauge cluster that I put in a couple months ago.
BigDaddy13440
Rome, NY
$150 difference between a set of 4 33s vs a set of 4 34s. I'm kinda leaning towards the 34s because I love the stuffed look. With a 3 inch level lift those will fit nice and tight.
View attachment 82505View attachment 82506
33.8" for the 305's vs 32.7" for the 285's - the 305's should fit without any problems, IF your wheel width and offset is correct.
I'm looking at a used set of 275/65/20's to throw on my Denali 20's, 34.1" if new. Figure they'll fit with just my keys/springs/blocks, because they aren't nearly as wide as 35x12.50's (just under 11"). Once I see how much clearance I have with them, then I'll decide if I want to put the body lift I have on and step up to 35's.
Luggz
