Z71/limited fog lights
tahoe.mkIII
aloha ladies and gents.i have spent the last few hours trying to find an answer on here and the rest of the interweb, but to no avail.(anyone else but me think the search function on most forums is kind of weak? all words 3 letters or less are too short or common? "z71 fog lights" becomes just "lights") any way, got a new front bumper from lmc, z71/diesel.got it painted and mounted up, now im trying to track down some lights.LMC seems to have them($120 for both)i have spoken to 4 reps from LMC.2 told me they include the mounting brackets and will bolt right up, the other 2 reps say the exact opposite...anyone on here know?
thanks-nh-
Tbruz
Windham NH
It depends on the year......
2000 Tahoes came in two body styles the Old Body Style and the NBS new body style.
The 1995 thru early 2000 gets its foglights in the bumper.
The late 2000 stylre onward gets its fogligts under the bumper in the front valance.
The in bumper fog lights(OBS) are available for around 100 to 120 a set shipped.
They do not have the mounting brackets which is actually a mounting bucket that fits inside the bumper from the backside. BTW, You'll need to have the bumper off the truck to add these buckets/fog lights.
NBS fog lights have intergral mounting brackets as part of the lights.
I have a spare set of GM OBS fog lights with the mounting buckets available for sale.
Also have a spare fog light switch available, another hard to find part
Let me know if interested in either.
Tbruz
Suburbinator
San Marcos, CA
Use Google to search the forums. To get the exact phrase, enter the entire next line(at Google.com of course), and use quotes:
"Z71 fog lights" site:www.tahoeyukonforum.com
To get the three words in any order, don't use quotes:
Z71 fog lights site:www.tahoeyukonforum.com
tahoe.mkIII
tahoe.mkIII
thanks for the quick responses guys.tbruz i am interested in purchasing the lights.need 2 more posts and then i can pm you
---------- Post added at 11:52 PM ---------- Previous post was at 11:48 PM ----------
post #10
i have now gained the elite privilege of private messaging
---------- Post added at 11:53 PM ---------- Previous post was at 11:52 PM ----------
dammit.last one didnt count...neither will this im guessing...
effort in futility
Tbruz
Windham NH
Nate,
I can go $160 + shipping on the lights with mounting buckets and $40 on the fog light switch.
Let me know your zip code to calculate shipping costs.
Are you adding these to a truck that had lights already or do you need to get the harnesses as well?
Search the Interior section for a thread by me on foglights, I just went thru this same add about two months ago and located all the parts and part numbers to add foglights to a 1997 thru 1999 OBS that did not have foglights from the factory. Its a bit pricey but pretty easy(skillwise) to accomplish.
Tbruz
tahoe.mkIII
tahoe.mkIII
not sure if it had factory fogs.i noticed two sets of paired wires coming off the main harness that perfectly reach both fog light holes (looked like factory installed wiring) i do not have an interior switch though...id like to buy them.zip is 07712.jersey
im going to go look for the thread you suggested
Tbruz
Windham NH
Nate,
Guessing you have a tailgate/lift gate versus barn doors.
if so those are most likley the dash end of the rear wiper harness and the rear lift gate harness.
Good news/Bad news, Good news, the 2 GM harnesses you need to add fog lights are available just not thru GM.
Bad news they're expensive, about $300 plus all together.
You can try an aftermarket harness company for around $100 but I have no experince with that
You also need a differnet plate for the dash where the foglight switch fits in.
I'll dig up PN and get back to you.
Tbruz
95BlackTahoe
Edinburg, PA
Also, I am not sure if any one is aware, but The olds bravada of the 96-99 era uses what looks like the exact same fog light as the limited...
Do a google image search for 98 olds bravada fog light.
We all know GM interchangeability...
Shawn
Tbruz
Windham NH
The fog lights themselves are available online at a bunch of places for around 100 bucks shipped.
The 2 mounting bucket are the issue, they're NLA and not readily available.
The switch itself is also NLA but you can find that occasionally.
If somone is creative they could probably figure out an alternative to the mounting buckets using sheet metal.
Tbruz
Monstar_est87
City of Angeles
Hey guys... As u may know I drive a LIMITED, stock with bumper lights... I have the vertical fog switch and wish to convert to a horizontal fog switch... I have both swiches, however the pins in the switches are different as well as the plugs... And im pretty sure so is the wiring... Does any 1 have the wiring diagram for the horizontal..? E.I. Wire colors..? Which wire color goes to wat pins..? Ill post up pix in a few hrs or so...
Monstar_est87
City of Angeles
Vertical switch
Horizontal switch
(barrowed photo)
So again its the harness for the 1 in the 4x4 location I need help with...
95BlackTahoe
Edinburg, PA
This should work for you...
The Plug...
The wiring...
In your case, It appears the follow applies for that horizontal switch...
Pin A Gray
Pin B Yellow
Pin C Nothing
Pin D Brown
Pin E Purple
Pin F Black
Hope this helps...
Shawn
CrackerJack135
