Z71 fog light bulb
brian.roberts.1293
Durham NC
I am wondering what kinda bulb the fog light on a Z71 takes as I'm looking to upgrade to an led bulb.
Sent from my SAMSUNG-SM-N910A using Tapatalk
B
brian.roberts.1293
Durham NC
I know the regular suburban fog light is an 880 bulb but not sure about the Z71.
jough
Arkansas
If the back of the bulb has a straight connector, then it is an 880. If the connection is at 90 degrees, then it is a 9145.
I used a US store's guide on eBay and the original order didn't fit.
B
brian.roberts.1293
Durham NC
Ok so I was just looking how do you remove them it's a solid hosting behind the housing. Have to remove the whole light?
jough
Arkansas
You should not have to. Just remove the connector on the back of the bulb, then twist the bulb 90 degrees (can't remember which direction) and remove. If you take out the whole fog light, it could mess up the adjustment. It has been a year since I replaced mine, so I'm a bit rusty on what I did.
On Z71s the lower air dam, which houses the fog lights, is designed to be easily removed for more serious off road use.
Hodmjstone
