With a 1" lift, would you do 305/45, 285/55, or 285/50 tires?
Phatjoe
Hi,
I'm looking to do a 1" lift on my yukon Denali Ultimate. I'm looking at 305/45/22, 285/50/22, or 285/55/22 tires. I'm looking to avoid any rubbing or cutting. Any sure recommendations? Also, I'd to stick with the stock wheels.
I think the 285/55 may be too tall. The tire selection for 285/50 is quite limited. I may have to run with the 305/22s, just not sure if they are too wide.
Anyway, your feedback is greatly appreciated. Thanks
I run 305/50x20 on my 07 Denali, and I don't believe that you would have any rubbing with the 305/45x22 on a stock wheel.
olyelr
Elk Rapids, MI
I put 305/45/22 toyo open country at3’s on my wifes high country. They fit perfectly with no rubbing with no level, although i did level it an inch and a half later on.
Also, one thing to consider, most 305/45’s are xl-rated tires, not the e-rated truck tires like most of the 285/50 and 285/55’s. I would think the e-rated may ride a bit more harsh…maybe not though.
Zmfrancik
Do you have air ride? I have an LT with normal suspension and want to pull the trigger on 305/45r22s. I have the 22” factory black multispoke wheels. Just want to make sure they fit before pulling the trigger. I’m really only worried about rubbing with the ball joint and knuckle.
olyelr
Elk Rapids, MI
Nope, no air ride.
Zmfrancik
Just got some 305/45r22 recon grapplers delivered. Will post pics when I get them mounted on Monday.
Zmfrancik
Hell yea looks nice man !
Thanks! Can you tell me what pressure you have yours set too? They set it to 37 at the shop. I read somewhere it should be like 32 based on Toyos inflation table.
olyelr
Elk Rapids, MI
Right around 32-34 psi. She has 34k on them now and still in good shape.
Trey Hardy
Hey did these tires fit without lifting the tahoe? I have a 2024 yukon denali and am thinking about buying these but don't want to get into lifting the vehicle.
Should fit fine from previous posts. However it’s no big deal to put a 1-2” leveling kit on and shouldn’t take any real major modifications it simply slips under the shock and can be installed in 30 min
olyelr
Elk Rapids, MI
Do you have air ride? If so i suppose there could be minor rubbing when in the lowered mode turning sharp…not sure on that though.
HopheadFury
I do not have air ride
Just did this on my 24 Yukon Denali (non ultimate). Left suspension stock and did 305/45r22 and they’re great.
Drewphil
