Wiring Schematics 2015+
LA Driver
Shoot....do you know if there is one lower that comes out near the pedals?
Supercrewzn
That yellow mark is where you need to slice the boot. Use a stiff wire and go through the top inside boot. You can feel when you get inside. Use wd40 to help wires slide. I do this everyday on police tahoes.
Supercrewzn
I need the wiring diagram for the door triggers on 2015 tahoe.. anyone have that? Alldata hasn't updated yet
lilmac
I switched out front console to jumpseat. Do you have the diagram for the harness that goes to the console? Should be for rear hvac controls, power outlets(12 and 110v), usb ports and such. Want to transfer as much as I can to the jump seat.
Bill Francis
I see that 2 have asked, but no response.
I need to know the video source on a 2015 Yukon XL Denali. I already have the rear screens, but I want to add a screen for a rear facing car seat. I would like to know the wire or where I can tap to get video out.
Kpwweb
Anyone have instrument cluster wiring for a Tahoe with DIC and one for a Denali?
Kpwweb
should be the same or you should be able to put the chevy one with the screen in yours
I have the Chevrolet multi-colored DIC in mine. The techno-geek wants to explore swapping the big-screen Denali gauge cluster into mine. I was told it wouldn't work, but I'm from MO!
DenaliBQ
you have the 4" screen or the 8" one and either way it should work
i want to see if i can put the escalade one in my denali but that will deff need some programing all the connections are the same tho
joshs2000ss
Schematic for the wiring to the buttons that activate the 2nd row bucket fold up release?
cmatt
Wiring harness from the vehicle to the headlight assemblies for the halogen vs. HID's on a Yukon? I've confirmed the two wiring harnesses have different part numbers, but not sure about the connectors, wire pin locations, etc.
Kittmaster
Is there a place to get a disc ISO that has all the diagrams to a specific vehicle? I have a thread trying to find factory services manuals for a 2016 Yukon XL. Figured I'd ask here. TY.
CHofheins
The wiring schematic has been a great help. One last issue. I cannot find a remote wire on the factory amp to use for the aftermarket amp. Any ideas
horn1004
Hey guys and gals! This is my first post here and I'm looking for some help. My wife has a 16 Tahoe LTZ with the Bose and sub. I'm trying to replace the front dash speakers and the rear pillar speakers and need some help determining positive and negative wires for each speaker. I've looked at the schematic and thoroughly confused myself. If you look at T3 audio amplifier x2 pin 1 is left front tweeter -. Pin 13 also says left front tweeter -. Pin 5 is left front tweeter +. Pin 9 also shows to be left front tweeter+. Any idea what the correct colors are for the front and rear tweeters? I called Crutchfield but they didnt have much information yet. Also, on x1 pin 4 shows as battery positive voltage. Is this a 12v switched wire? It'd be great if it is as I need to run a remote wire for an amp that I'm adding. Thanks for any help you can give me!
Kpwweb
Anyone have a wiring diagram for the front hvac/climate controls? Seems my wife is burning up and I'm freezing to death!
Thanks!
AngelXL
Radio
RM1234
Hi!
I saw this thread with the audio schematics and thought it was exactly what I was looking for. Thank you for that! I was wondering if anybody has any knowledge about the problems in the audio system?
I have a 2015 GMC Yukon XL and the warning sounds (when the car starts, when I turn the turn signals) started to disappear. They could be faint when I start the car (I believe they are wired to come out of the left front speaker under the windshield) and then disappear completely. Sometimes they come back. The radio works however, including from that left front speaker.
Could the wires responsible for this just be loose or would you think it's a bigger problem? And I was wondering if you could point me to where I would find the Radio X1, X2 and X3 connectors inside the car, please?
Thank you!
RM
Conedaddy
