Wiring backup camera NBS?
Discussion in 'Audio & Electronics' started by Slammedchevy01, Jun 21, 2017.
  1. Slammedchevy01
    Slammedchevy01 Full Access Member
    305
    20
    Feb 9, 2010
    Name:
    Adam
    Looking at installing a auto vox cam1 backup cam in my 2003 Tahoe. Did you tap into power at taillight and which wire at rear harness if you remember?
    I believe I can grab power under the dash by bcm or just use reverse wire. Guess I don't need camera on all the time.
  2. shreksbrother
    shreksbrother Full Access Member
    319
    278
    May 9, 2017
    Auburn Hills, MI
    Name:
    Adam
    I have an always-on camera. I ran the power from the dash. I could not find switched power anywhere in the rear compartment. And yes, the reverse light is where you would want to tap it if you want it only on when backing up (I caught my reverse wire off the factory towing harness).
    Slammedchevy01 likes this.
  3. Slammedchevy01
    305
    20
    Feb 9, 2010
    Name:
    Adam
    Thank you, then tapped into reverse wire at bcm for headunit?
  4. HurricaneSSeason
    HurricaneSSeason Member
    65
    17
    Sep 4, 2010
    SC
    Name:
    Red
    Do you remember the color of the reverse light wire in the towing harness?
  5. Doubeleive
    Doubeleive Supporting Member
    4,568
    2,991
    Name:
    just google the trailer connector wiring diagram, it will show which pin is reverse then just tap the wire behind the connector at the corresponding pin, use a meter and confirm it first of course.
    HurricaneSSeason likes this.
  6. Crippin87
    Crippin87 Full Access Member
    136
    94
    Mar 2, 2017
    Name:
    James
    This yellowish wire under the dash is the one that you are looking for. Last plug, bottom row 4th pin from the right hand side. I just tapped into it for mine, the purple wire is the wire to my head unit. Hope this helps!
    334583D5-50ED-4070-BF33-63EA82EC6839.jpeg 632ABB90-E3A6-4989-B255-83E2F87A3C76.jpeg F5D4CA03-BF22-43C1-A84E-544F1979C13B.png
Share This Page
