Winter Wheel Setup
johnnyjr79
I have a 2022 Tahoe High Country with air suspension. I’d like to put an 18-inch winter wheel setup on.
I don’t see any issues and it appears the wheels will fit.
I’d appreciate any advice or things I should look for.
MoonTruck
There are a few posts discussing this very same thing. I recently inquired about the air suspension and wheel size as well. You shouldn’t run into any issues. I plan on using 20s for my winters. I bought a set of take offs to wrap.
Do a search for winter tires or Michelin Defensers, bunch of people having discussion about their tire set ups, I was just reading some.
Jettix2
18 Silverado takeoffs with Blizzak DMV2 on our ‘22 Burb and it’s unstoppable in the snow.
66 Galaxie
Just put on 18” Trail Boss replicas with Blizzaks and ready for winter
johnnyjr79
johnnyjr79
New wheels were installed and had no clearance issues.
Do I need to do anything to adjust the speedometer reading? The installer said no, but I want to double-check
She's a little dirty, but the wheels look great.
Thanks again
MoonTruck
I believe so long as your overall diameter 33” doesn’t change you are good. The rotations stay the same.
WalleyeMikeIII
Sunny and Snowy Minnesota
If you went with the Stock 20” Size of 275/60R20, there is a .2 inch difference in diameter, which results in about 0.2% difference on the speedometer. I’d not sweat it.
johnnyjr79
johnnyjr79
I’ve had the tires on for 2 months and I’m now relieving the speedometer is reading about 3 mph slow.
I assume I have to go to Chevy to have them reprogram the computer.
Any advice? I may need to decide whether to run the setup all year or change it so both wheel setups are the same.
Here are the two setups I have.
265/65R18 112T
276/50R22 111H
tom3
Do you use navigation on any road trips? That could confuse the issue a bit. Otherwise if no codes I'd not worry about it. Good looking machine!
scottd
