Will 37's fit
custom99
Pittsburgh, Pa
I just finished installing a 6 inch suspension lift on my 2001 Yukon XL 2500. Anyone know if 37x12.5-18 will fit. I found a set on Craiglist and its a bit of a drive. Worth the drive if I know they will fit. The rims were being used on a H2 Hummer previously.
jdpber
GOLD MEMBER
The America
No they will not. Not without more lift.
I have a 6" and 35s.
I mean yes 37s will fit but you will not be able to turn the wheels so it would be useless.
For you to clean 37s and turn. You would need to add a 3" body lift
jdpber
GOLD MEMBER
The America
Wheel wells limit us
Exactly why I am such a huge supporter of GM to get away from the square well and go to a round well. Take the wells on the 250+ body's they can clear 35s with a 2" level kit. Yet I need 6" suspension and some trimming depending on offset.
Donnie Yukonie
Yates Caretaker
Agreed , however I do like the Looks of a square well a little better
Max
Mile High
Denver
They'll fit depending on wheel and offset. The 2500 trucks sit a tad higher lifted, which kit are you running? I've done 37s on a few 2500s.
McAllister513
I fit 37s on a 01 Tahoe 1500 2WD with a 6" Fabtech & 1.5" body lift. Requires some trimming but it looks amazing!
Dillonv2008
Sac
I had 6" with 3" body they fit fine look good but if mudding you'll rub! From flexin little bit. + you'll have to tighten your tbars all the way up which is going to cause more stress on your wheel hub bearings and cause Camber problems and wear your tires out faster and my 37s were bold to and I was having problems still when turning sometimes and rubbing jus from body flex in sharp turns. I know took my 37s off and have 35s.
---------- Post added at 09:55 PM ---------- Previous post was at 09:54 PM ----------
that's mine with 37s
And this is it with the 35s on 20s
Brace
