Wierd Issue with 2007 denali
JML07denali
I noticed the other day slight flicker dim of the headlights. Upon closer inspection it looks like all the lights flicker from headlights. To tail lights and even the interior lights? I thought it might be a loose ground from the battery but I checked and all is tight. Has anyone had this problem before? Could it be the battery or alternator? Need some direction.
Thanks for any light you can shed on this.
08grey
Negative wire is know to break down over time and corrode. You can run a negative right to the chassis and to the motor and to the negative of the battery pretty simply. Or look up big 3 upgrade. You will notice the ground is pretty shabby and only runs to the motor.
osidesurfer365
San Diego
I had similar issues, new battery but lights would flicker and it wouldn't start sometimes. I had the negative battery cable replaced with a newer one and better grade. All problems went away. There is a thread about this on here I will try to find for ya.
GM Customer Service
Michigan
I understand that you have noticed an issue with your head lights, JML07denali. I'm glad to see forum members are beginning to step in with feedback. I might not be able to provide you any technical advice but if you have any lingering concerns, please contact by private message.
Jennifer T.
GM Customer Care
Dh1280
