Wide band O2 location
J5races
Hello all, new member but been lurking for a while now. I’m adding a Whipple Gen V kit to my 2018 Tahoe RST when it arrives.
I bought an Innovative PSB-1 AFR and boost gauge. I have a few questions:
1) where should I have a bung installed for most accurate AFR? I realize I’ll only be looking at one bank of cyl
2)Where should I get my boost reference for the gauge?
3)Which wires do I tap into by the driver foot area to get the lights/switched power/etc for this gauge? I’m good with wiring just need to know what wires are what I need. I’m extremely handy with a soldering iron. But don’t know the Pino it’s of the Tahoe
Thanks all!
Jon
mb1500
Only 1 WB sensor you want to be shortly after the y merge so you get both banks on the reading. Typically the sensor MFR will give instructions on where they want it located.
Should be an unused port on the back of the manifold you can use for the boost ref.
Thrust
ICT
Thanks all!
Jon
I have the same sensor but have not installed it yet. Instructions on page 7 states before the catalytic converter and between 9:00 and 3:00 o'clock. Preferably at 12:00.
Goat rope garage has a decent video of where he put his wide band.
Whipple should have a plug port on the aft side for using as a boost/vacuum reference point for your gauge.
J5races
J5races
But that would be after the primary cats right. Isn’t that bad because cats change the oxygen reading?
J5races
J5races
I don’t have the parts yet. All on order. Been saving up for the whipple for a while now.
Anyone know about the wiring?
Thrust
ICT
This looks like a good spot.
Thrust
ICT
Also found this for wiring to make the gauge work at night.
Thrust
ICT
And Power Distribution wiring diagrams.
Thrust
ICT
And the rest.....
Jeff_
Scottsdale, AZ & N. Idaho
Do you have long tubes?
Do you still have secondary cats? If so, just put it in the secondary cat.
Are you wanting the wideband permanently mounted inside the cab? If so run the wires through the firewall.
I just plug mine in and hook my laptop up when I want to data log (cord ran through the window and painters tape holding it along the door so it’s not flapping in the wind) and then unplug it all when I’m done. Power for my AEM wideband is supplied through the 12v cigarette lighter.
Don’t need a permanent AFR gauge hooked up personally.
golavaman
