Which AC line is this?
Matthew Jeschke
Sahuarita, Arizona
There's a line leaving the compressor, it goes directly to bottom of condenser unit. It's leaking on my truck and I need to replace it but I cannot figure out what hose that is called? It's a 2001 Z71 Tahoe
Thanks!
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
It is bottom connection on compressor closest frame. It runs up towards the condenser unit. Not sure if is top or bottom connection.
I have rear air. The splitter connection above goes to fron evap and rear evap.
Sent from my SM-A505U using Tapatalk
corvette744
2004 Z-71
Northern illinois
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I keep lookong there... hrm. I hate to go to effort to take it apart. before i get the part.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
That's awesome. Yeah I may leave all else be. I rebuild the system not long ago. (minus compressor). I put all new seals, expansion valves, etc.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Ah sheep Sheet beaches hahaha
I installed the line, it was the discharge / suction line. New one is great, no problems with it. However, I thought dang I should probably replace the oriphice tube while I am in there.
I charged the AC with two cans of refrigerant and the low side runs too high. I get 70 PSI on low side. What could cause this? Could it be a bad oriphice tube?
I should be getting 55 PSI on low side.
dizhai
