Where's My Oil Going...?
Yukon5.7
Lake Ann, MI
Recently I have noticed that my 99 Yukon has been loosing about 3/4 of a quart of oil about every 500 miles. I'm lost the truck does not burn oil going down the road. There are no signs of leaks. Where else can it go..?
I have also noticed the lifters will knock on a chilly morning.
grnrpr68
Davenport IA
if its not leaking on the ground or on the motor then you probably burning it out the tail pipe
h0tr0d
Brenham, Tx.
It's hiding from you...waiting to spring forth and soak you next time you crawl under the car. lol
If there aren't any drips on your driveway, check underneath the car and look for buildup on crossmembers etc. if it's coming out in a mist while you're driving down the road. Otherwise, you're burning it.
BWdiver
Like the others said, if its burning the oil let it idel for 15 to 20 mins and have someone get in side and rev it up and look at the tail pipe to see if you are getting any trace of white or blue smoke if you are your rings are going bad more than likely.
vsaravia
