Wheels
98blackbell
FL
Issue vibration!
Situation. Truck has developed a vibration that gets worse as you increase speed. The vibration is a come and go. It can get violent at times. Had tires balanced again yesterday and they say they spun true. This is not acceptable.
Wheels are 20" Boss 300 series 5 spokes. Have had for 2 1/2 years. Tires are Nexum 275/45. Just installed DJM drop kit 4/4. Road smoothly when first installed. New Calmax shocks all the way around.
What gives? Any suggestions?
THE YETI
Director of Operations
South FL
cheap tires. could have broke a steel band inside the tire.
Oklahoma
Issue vibration!
also if tires arent the issue, might be something more serious such as a bent/ out of balance drive shaft.
98blackbell
98blackbell
FL
thanks, took it to the local "stealer" I mean dealer to look at. First tire the checked was out an ounce. Thats allot. What gives pep boys?
I lost my cruise control this past week. Dealer calling for a new controller $950. I found this after market that will take the plug from the factory module and plug right in. Mount it, attach to the linkage and I'm done all for 175!
Yeah I know when I put the drop kit in I was rubbing the shaft a little till I found it and had to trim the floor supports to clear the drop.
Gab Morgan
Wheel is very much important because your car or any type of vehicle can't move with out this but we have to make sure that for everything we buy theirs a quality to see the effect of durability of every products...so we have to use the tamper evident labels for the security.....
---------- Post added at 12:22 PM ---------- Previous post was at 11:57 AM ----------
Can I ask you a question guys? because I'm searching for the forum sites about tamper evident labels but I can't see exact forum that post and discuss with this matter can you tell me what's the connection of labels about it......will you?.....lol
BlacktopBandit76
