Wheels offset?
grilled2003
South Florida
How can I find out the offset of the wheels?
Is there anywhere on the wheels that offset would imprinted?
Thanx guys
DwDrummer
AL
If the tires are mounted on the wheels most of the time the wheel manuf. will have a sticker somewhere with all the info. You can also look on the back side of the wheels usually on the faces and they are usually stamped there too. Hope this helps!
Thanks,
Derek
MOBmentality
Has a $25,000 Punch
some wheels only come in a certain offset per size.. so you could get lucky and just look up your wheel online and see what options is has.. Some will have 2 offsets.. a FWD/RWD if this is the case yours will be the RWD one.. or most likely the lower number
(+40 (FWD) vs +15 (RWD))
Luggz
