What's the chime I get a few minutes into a new drive?
KMeloney
I keep forgetting to be on the lookout for what causes the "ding-a-ling" chime I get upon setting out on a new drive in my '23 Yukon -- and then when I hear it, it's too late to recognize what might have caused the chime.
Retroactively, I've thought that maybe the speed limit icon popping up on the dash is related to the chime, or if it chimes when the cameras pick up the first car in front of me, or... I don't know. It could be something through CarPlay for all I know. Whatever the case, it happens early in my drives, maybe not until I get on a main road with yellow lines dividing the two-way traffic, and I won't experience it again at all during that engine cycle.
Thoughts? Thanks!
StephenPT
St. Helens, OR
Take a look at the little bell in the upper left corner of your infotainment screen. If there’s a red dot there, tap it and see what the notification is.
Jimbo123
Could be letting you know you're at a school zone too. Mine will make a noise to indicate that.
KMeloney
KMeloney
The school zone chime makes sense, especially based on the areas I think it has occurred. And in full disclosure, I haven’t checked the manual to see if there’s anything about this chime in there. Think there is??
KMeloney
KMeloney
What about upcoming RR crossings? Got the chime on a different road from where I’ve most noticed the chime before, but there was a RR crossing on this road, same as the other road. Seems maybe I got the chime @ the same distance from this crossing as the other.
Otherwise, no school zone today, and no notice on the bell icon next to the Driver tab on the nav screen…
Marky Dissod
IFF ALL ELSE FAILS, check to see if:
you've any food stuck in your teeth
you've a booger hanging out of your nose
you left your button unbuttoned, your shirt untucked or your flye open
you left something behind / forgot to bring something with you
Amazing, these new vehicles ...
Jerboy23
You have the speed limit alert set at a low speed - it should show on your in dash screen though as an alert along with the beep.
KMeloney
KMeloney
Thank you. I DO have the speed limit sign in my dash screen. Ok, so that's a low-speed [limit] alert? Alerting me that the speed limit is under a certain speed in that location? I'll look it up in the manual. Thanks!
BigdawgR6
No it's a speed limit alert that you may have set too low. You can set the alert to chime once the vehicle exceeds the limit you have setup. I completely turned that off because it's pretty annoying.
KMeloney
KMeloney
If we're talking about the same setting, it LOOKS like it is/was set at 55 -- and I've only gotten this chime maybe doing 20-25. So, either I haven't looked at the correct setting, or this chime I'm getting is unrelated.
KMeloney
KMeloney
SOLVED THE MYSTERY!
It is, in fact, a RR crossing alert from Waze. I have my phone auto-sync whenever I get in the truck, but don't necessarily have Waze up on the screen. Last night, where I thought I had gotten the chime before, I made sure to put Waze up on the screen -- and voila, along with the chime, Waze showed a visual alert that there was a RR crossing ahead.
Thanks for the input, folks. Now we know.
SOLVED THE MYSTERY!
ya waze added that sound about a year ago, I was puzzled the first couple times it happened as well but figured it out fairly quickly because I cross 4 set's of RR track's in a short period on a typical weekday drive for work. there is a option in settings to turn it off if so desired.
j_jerry79
