What should I do next?
Denali22
Fairfax Va
I have a black o3 yukon denali on 22 TIS 07 lowered tor and springs Borla exhaust led tails clear corners halo headlights and apparently 14% tint according to the cop who I talked out of a reckless. I also just put on new brake lines brembo rotors and ceramic pads and just got it wet sanded and all the big dings. So what do you think I should do next? I'm thinking headers, intake and tune? Also I only want to spend a 1000.
D
Denali22
Fairfax Va
I actually only wanna spend around 700 b.c i have to get new shocks in the rear one of mine blew when the airride clip came off after I lowered and I also have a denaligril gril
blueflamed03
Oklahoma
$700, that takes out headers.
I say for $700, look at what factory gears you have, and what size tires. When you put bigger and heavier tires on, you kill low end, and loose low end TQ. new gears will help that. But this will need to be done before a tune so Justin can calibrate for new gears. Gears will cost about $250 and about $300 to install. So that's $550
Then spend the rest on a Black Bear tune.
You can spend over $700 on headers alone, much less adding a tune,etc.
05Yukon
Houston
I think gears would cost more than that to do both front and rear. I have heard most people get quoted over 1000 to do a full gear swap.
blueflamed03
Oklahoma
05Yukon, you are indeed correct, i just re-read and picked up the Denali part....my bad!
brice715
