What should I do next for my heat to work? heres a diagram and what ive done...
SunlitComet
OBS Jedi-Do Good
unknown at this time.
No vacuum on the hose that goes from solenoid to water valve at all, dont recall the numbers from the test as a friend did it for me
if you can get thoses numbers it would be great but that circuit i think is where your problem lies. but for now if really needed butt those two hoses together to see if the heat gets going for you.
---------- Post added at 09:03 PM ---------- Previous post was at 09:02 PM ----------
i should have the full tech data in front of me Tuesday i think. will help some more.
K
knoslf
Thornton, CO
Thanks man, put the hoses together?...as in removing the control valve all together? and put the hoses together?
SunlitComet
OBS Jedi-Do Good
bypass the firewall solenoid. get some plastic hose fittings from your local stores hardware parts section and stick both vacuum hoses together. simpler then dooing the coolant lines and making a mess right now if you need the heat now.
K
knoslf
Thornton, CO
Thanks! Gonna do this today, and just keep the control valve til next summer lol...
DSRBLDR47
