what ratio for front axle assembly
ORM1
Hi,
Just blew the front carrier assy on an 18 tahoe premier with just under 100k miles. Is this common? and is there anything i could have done to prevent this? also looking for a replacement, I have the part # but can't seem to verify what the actual ratio is, motor is a 6.2. I did a vin lookup and it states the rear is a 3.08 just cant find anything on the front. will appreciate any input, Thanks
Blackcar
Hi,
The front will have to be same ratio as back.
Are you driving vehicle in auto 4-wheel drive?
Hi,
You go the RPO sheet for your specific vehicle and not a generic one? I didn't know that K2 6.2s came with 3.08s. Thought they got 3.23s.
Send me your VIN and I can get your RPO sheet from GM.
O
ORM1
I will promptly!! Thanks
O
ORM1
I was in auto, always drove it in auto. after the news today, The shop asked me to switch to 2wd until parts can be sourced
This is a nicely optioned truck!
1LZ PACKAGE LZ OPTION 1
1SZ DISCOUNT OPTION PACKAGE
4AA INTERIOR TRIM JET BLACK
5JL ACCESSORY BRAKE UPGRADE PKG 1 - COMPLETE
6ZP COMPONENT FRT LH COMPUTER SEL SUSP (6ZP)
7ZP COMPONENT FRT RH COMPUTER SEL SUSP (7ZP)
8X2 COMPONENT RR LH NON-COMPUTER SEL SUSP
9X2 COMPONENT RR RH NON-COMPUTER SEL SUSP
A31 WINDOW POWER OPERATED, ALL DOORS
A45 MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER PERSONALIZATION
AG2 ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL
AKJ WINDSHIELD STYLE SHADE BAND
AKK WINDSHIELD STYLE ACOUSTIC PVB
AKO WINDOW TYPE PRIVACY
AKX WINDSHIELD TYPE SOLAR ABSORBING
AL0 SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
AN3 SEAT FRT, INDIVIDUAL (NON BKT)
AP9 NET CONVENIENCE
ARL PLANT CODE ARLINGTON, TX, USA
AS8 SEAT THIRD ROW 60/40 BENCH, POWER FOLD
ATH LOCK CONTROL, ENTRY REMOTE ENTRY, EXTENDED RANGE, PASSIVE ENTRY
ATN SEAT RR BUCKET, POWER CONFIGURABLE
AU3 LOCK CONTROL SIDE DR, ELEC
AXP VEHICLE TYPE MULTI-PURPOSE PASSENGER VEHICLE
AYQ RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS FRT, FRT SEAT SIDE FRT INBOARD SEAT SIDE, ROOF SIDE
B30 COVERING FLOOR CARPET
B58 COVERING FLOOR MAT, FRT & RR, CARPETED INSERT
B86 MOLDING B/S BODY COLOR
B8Z VEHICLE GM PROD WEEK 50
BTM SWITCH ENGINE START, KEYLESS
BTV REMOTE START ENGINE
BVE STEPS, RUNNINGBOARD SIDE
C25 WIPER SYSTEM RR WINDOW, INTERMITTENT
C49 DEFOGGER RR WINDOW, ELECTRIC
C6A GVW RATING 7, 300 LBS
CE1 WIPER SYSTEM WINDSHIELD, PULSE, MOISTURE SENSITIVE
CF5 ROOF SUN, GLASS, SLIDING, ELEC
CJ4 HVAC SYSTEM AIR CONDITIONING, FRT & RR ELECTRONIC CONTROLS
D07 CONSOLE FRT COMPT, FLOOR, CUSTOM
DCP PROCESSING DIRECTIONS & CONNECTIONS SERVICE PACKAGE
DD8 MIRROR I/S R/V LT SENSITIVE
DL3 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED POWER FOLDING, TURN SIG IND, LT SENSITIVE, COLOR
EF7 COUNTRY UNITED STATES OF AMERICA (USA)
FE9 CERTIFICATION EMISSION, FEDERAL
FHO VEHICLE FUEL GASOLINE E10
G80 AXLE POSITRACTION LIMITED SLIP
GU5 AXLE REAR 3.23 RATIO
GXG PRIMARY COLOR EXTERIOR, IRIDIUM MET (121V)
H2X INTERIOR TRIM CONFIG LEATHER, LEVEL 4, JET BLACK
I18 ENGINEERING YEAR 2018
IO6 RADIO INFOTAINMENT SYSTEM - UPLEVEL HMI, ENHANCED CONNEC TIVITY, EMBEDDED NAVIGATION
JD9 BRAKE VAC POWER, 17" DISC/DISC, W/VSES, 7700 LBS
JF4 PEDALS ADJUSTABLE, POWER
JL1 CONTROL INTEGRATED TRAILER BRAKE
K34 CRUISE CONTROL AUTOMATIC, ELECTRONIC
K47 AIR CLEANER HIGH CAPACITY
K4C CHARGER INDUCTIVE PORTABLE WIRELESS DEVICE
KA6 HEATER SEAT, RR
KC4 COOLING SYSTEM ENG OIL
KI4 RECEPTACLE ELECTRICAL, ACCESSORY 110 VOLT
KNP COOLING SYSTEM TRANS, HD
KQV HEATER SEAT, VENTED, FRT
KRV REFRIGERANT LOW GWP
KW7 GENERATOR 170 AMP
L86 ENGINE GAS, 8 CYL, 6.2L, SIDI VVT, AFM, E85 MAX, ALUM, GM
MAH MARKETING AREA US, PUERTO RICO/USVI
MF6 TRANSMISSION AUTO 10 SPD, 10L80, GRX, GEN 1
N38 STEERING COLUMN TILT, TELESCOPING, POWER
NE8 EVAPORATIVE SYSTEM LEVEL 3 EMISSIONS
NKC NOISE CONTROL SYSTEM, ACTIVE NOISE CANCELLATION
NP5 STEERING WHEEL LEATHER WRAPPED
NQH TRANSFER CASE ACTIVE, TWO SPEED, SWITCH ACTIVATED, ALUM
NTB EMISSION SYSTEM FEDERAL, TIER 3
P3H ORNAMENTATION EXTR, BOWTIE
PCJ CONTROL SALES ITEM NO. 103
QST TIRE ALL P285/45R22 SL 110H BW AL3
R6Q CONTROL SALES ITEM NO. 16
R9N CONTROL SALES ITEM NO. 89
RC4 TIRE SPARE P265/70R17 SL 113S BW
RIB ACCESSORY FLOOR LINER - CONTOURED - 3RD ROW
RUF WHEEL SPARE 17 X 7.5, J, STEEL, DESIGN 1
SAF LOCK SPARE TIRE, HOIST SHAFT
SCN APPEARANCE PACKAGE SPORT
SFE ACCESSORY WHEEL LOCKS
SGK WHEEL 22 X 9.0, J, ALUMINUM, DESIGN 6
SLM SALES PROCESSING STOCK ORDERS
T3U LAMP FRT FOG
T4F HEADLAMPS HIGH INTENSITY DISCHARGE
TC2 BODY EQUIPMENT LIFT GATE, POWER, HANDS FREE
TDM MODE TEEN DRIVER SETTINGS
TQ5 SENSOR HEADLAMP HIGH BEAM AUTO CONTROL
U2K DIGITAL AUDIO SYSTEM S-BAND
U2L RECEPTION HD
U42 ENTERTAINMENT PKG REAR SEAT, SINGLE DISPLAY, REM CONTROL, AUX JACK 2-WIRELESS DUAL CHANNEL HEADPHONES
U77 ANTENNA RR WINDOW, RADIO
UD5 PARK ASSIST FRONT AND REAR
UE1 COMMUNICATION SYSTEM VEHICLE, ONSTAR
UEU SENSOR INDICATOR FORWARD COLLISION ALERT
UFG SENSOR INDICATOR REAR CROSS TRAFFIC ALERT
UG1 OPENER GARAGE DOOR, UNIVERSAL
UHS DISPLAY INSTRUMENT DRIVER INFO ENHANCED (MULTI COLOR ENHANCED GRAPHIC )
UHX LANE ACTIVE SAFETY KEEP ASSIST
UHY COLL IMMINENT BRK LOW SPEED, VEH FWD MOVEMENT, BRAKE PREFILL, INTEGR ATED BRAKE ASSIST
UJM TIRE PRESS INDICATOR MANUAL LEARN
UK3 CONTROL STEERING WHEEL, ACCESSORY
UKC SENSOR INDICATOR SIDE OBSTACLE DETECTION ENHANCED
UMN SPEEDOMETER INST, MILES & KILO, MILES ODOMETER
UQS SPEAKER SYSTEM PREMIUM AUDIO BRANDED WITH SURROUND AMPLIFIER
UTJ THEFT DETERENT ELECTRICAL, UNAUTHORIZED ENTRY
UTR ALARM, HORN CONTENT THEFT DETERENT, SELF POWERED
UTT THEFT DETERENT BODY SECURITY CONTENT
UTU SENSOR, VEHICLE INCLINATION
UTV SENSOR, VEHICLE INTERIOR MOVEMENT
UV6 DISPLAY HEAD UP
UVC VISION REAR VIEW, MONO
UVD HEATER STEERING WHEEL
V54 LUGGAGE CARRIER ROOF, PAINTED
V8D VEHICLE STATEMENT US
VFF VIDEO FORMAT REGION 1, NTSC
VHM PROGNOSTIC SYSTEM VEHICLE HEALTH MANAGEMENT
VK3 LICENSE PLATE FRONT FRT MOUNTING PKG
VQQ ACCESSORY CROSS RAILS - ROOF RACK - INTEGRATED - BLACK
VRK VAA/COMPONENT REL ROOF TRIM
VRS ACCESSORY CARGO SECURITY SHADE
VT7 OWNERS MANUAL ENGLISH LANGUAGE
VV4 COMMUNICATION EQUIP MOBILE INTERNET CONNECTIVITY
WMJ VIN MODEL YEAR 2018
WPK SALES PACKAGE SPORT PACK
X88 MARKET BRAND CHEVROLET
XL7 FREQUENCIES RATING 315 MHZ, LONG DISTANCE
Y86 SALES PACKAGE ESS 1B
Y91 MERCHANDISED PKG LUXURY EDITION
YM8 IDENTIFICATION LIMITED PERSONALIZATION OPTION (LPO)
Z82 TRAILER PROVISIONS SPECIAL EQUIPMENT, H.D.
Z95 CHASSIS PACKAGE MAGNERIDE
ZY1 COLOR COMBINATION SOLID
You have 3.23 gears fore and aft.
AUTO is what killed your differential and will soon wear out your transfer case. It was not made for full time use, especially on dry pavement.
B-train
Keep it in 2wd unless is slick out (snow, ice, mud). Undue wear and tear is what happens, and now you've seen it first hand unfortunately.
Another thing to keep in mind is that the front differentials on these trucks (all the way back to the early 2000's) are know to get dirty quickly. Keep it serviced every 40k (along with rear diff, t-case, and trans) and you'll have less metal floating around chewing up bearings, etc.
you can get a used front diff for around $650 and slap it in, front diff failure is not super common, regardless of what mode you drove in
usually they begin to leak first, the pinion seal or pinion bearing is the cause. Other failures are less common.
a fully rebuilt one will be 1500+ anymore closer to 2k.
in the future as noted keep the fluid changed often and that also allows you to monitor the condition by how much metal is found on the magnet.
they should be available all over I can have my hands on one in a hour.
O
ORM1
AP9 NET CONVENIENCE
KA6 HEATER SEAT, RR
T3U LAMP FRT FOG
U2L RECEPTION HD
UV6 DISPLAY HEAD UP
Im grateful for this!!! cant seem to find a good source for a rebuilt unit. nothing available in the midwest.
O
ORM1
Thanks, found some sources local to me for uses units......cant seem to find anything rebuilt.
O
ORM1
I will, I know im due for all this work too since I had no history of service by previous owner, Thanks
O
ORM1
Thank you again!! duly noted!!!! wish I knew this before....
There are lots of proponents of leaving the transfer case in AUTO, including service advisors. When I first joined these forums there were several posts a month about failed transfer cases and the common theme was that they had all been driven around constantly in AUTO.
There are three MP3023 transfer cases in my driveway with over half a million miles between them and besides regular maintenance have only replaced a seal on one of them.
LKQ? They offer a warranty but have never needed it.
Don't worry too much about getting a used unit. Most of them are just fine. Just try and buy the lowest mileage unit that you're willing to spend for.
O
ORM1
Thats the goal sir!! Im really grateful.
AZPatriot1963
