What is the correct tire pressure?
Csurp
Fort Lauderdale, FL
2017 Tahoe LT 2WD, tow package, stock 18" wheels, stock Michelin tires.
B pillar tag states 35psi which is what I have been running for two years. Manual states that this is the minimum. Tire sidewall shows 44psi max.
Yesterday I got the truck back from the dealer after a flat tire repair and all tires were inflated to 41psi.
I didn't notice this until after I left.
Thoughts?
PG01
Up here to the right
Whatever you feel comfortable with and watch how the tires wear. I personally like more air for a stiffer ride....
Hobert
Downers Grove, IL
My 2019 Suburban Z71 with 18 inch rims and goodyear wranglers was delivered with tires at 37lbs. I usually run a few pounds above the minimum on my vehicles and will keep them at 37lbs. It rides great.
LT1ZOB
I run 36 cold. 15k miles, no wear issues
Csurp
Csurp
Fort Lauderdale, FL
Mine rides fine at 41psi.
I was concerned about potential damage/tire wear.
At 8k/year probably not a big deal?
Will keep an eye on it.
I assume that larger whee/tire combos require the higher psi and the tech just missed that these are 18's?
PG01
Actually some of the bigger combos have less pressure than the smaller combos.
Stresst
Whatever the sticker say in the door jamb is the recommended. NEVER go by what it says on the sidewall. I like to run around 37, 38psi on these trucks.
Fosscore
Running 37-38psi on both 20s and 24s. Seems to be a happy medium.
retiredsparky
A tire dealer once suggested I go to a vacant parking lot or quiet street with a piece of chalk, mark a front and rear tire tread with a couple of lines across the tread, then drive straight for a short distance. The chalk will show you if the inflation is too much (center wear) or too little (outside tread wear).
Larry
Larry
gat0r
DFW
^ make sure tires are at operating temp for that ;)
gat0r
DFW
i run on 22s & for daily driving, i usually run @ 32-33 cold. that puts me @ 35-37 w/ tires warmed up.
i also like the playing card vs chalk trick... but both will work well
over inflate slightly & drive until tires are warm. slip a playing card under tire to edge of 1st lug. then slowly deflate tire until card drags on removal (if you cant remove card, you deflated too much)
varminpoolteam
