What headers for my corsa touring?
cjweb11
Houston TX
2007 Z71 5.3L just got the corsa touring in and looking for advise on header options
Thanks
Blazed
Accepting Donations
I've been looking at kooks for mine 2011.
But I haven't read anything about them tho. I have noticed they don't make a y pipe for the 5.3
THE YETI
Director of Operations
South FL
First and foremost.. Make sure you get high flow cats. DO NOT go catless. Trust me. Had touring without cats and it was extremely raspy.
Look into dynatech. Probably the best bang for the buck for a total header/y-pipe package.
cjweb11
cjweb11
Houston TX
Thanks for the info that helps a lot, I do plan on using cats and am aiming for long tubes, that dynatech setup looks pretty good, that is also the only long tube setup I've seen with a catted y-pipe to match
Am I missing something (likely) or are there not many other long tube muffler-forward setups like the dynatech out there?
THE YETI
South FL
There are a few. American Racing, stainless works.
You definetly need long tubes. Anything else would hurt more than help.
cjweb11
cjweb11
Houston TX
I will look into those as well, thanks. I have read a few "shortys are bad" type posts, what is the story there?
THE YETI
South FL
They just aren't beneficial for LS based engines.
NORCAL SS
SUV SUSPENSION GURU
american racing 1 3/4 they have a 3 inch catted y pipe. Ive been installing these on the suvs takes about 3 hours install very easy. Im getting 1 7/8 for my escalade
cjweb11
cjweb11
Houston TX
Thanks that was my next question about one with 3" collector and Y-pipe, I'm pretty much sold on ARH
they only come in stainless, do u usually have them ceramic coated? I'm thinking ill go ahead and fork the cash over for it but would like y'all's thoughts
NORCAL SS
SUV SUSPENSION GURU
i dont have my ctsv coated and has less space and i run their headers. If you want to do it go for it but honestly id just slap em in.
THE YETI
South FL
You don't need them coated. You could, but it's not going to make or break you.
Mine were straight stainless. They'll discolor a little from the heat.
cjweb11
cjweb11
Houston TX
Sounds good thanks guys, heres one guys take on why he doesn't do coatings and an interesting tid-bit on collector design (info which I'm sure you 2 are already aware of)
http://houstonperformancetrucks.com/showthread.php?8077-My-opinion-on-headers-and-header-coatings
This is the correct part from ARH for my 2007 5.3L 4x4 Tahoe application, correct?
GMT0734
LMPerformance only shows compatibilty with 07-09 Silverado/Sierra 1500/2500 (Not HD)
http://www.lmperformance.com/516782/27.html?r=y
Fastlane Turbo also shows compatibility with 07-11 Tahoe (2wd)
http://www.fastlaneturbo.com/americ...ithcatsfor2007-2010gmfullsizetruckandsuv.aspx
Probably over ANALyzing Just making sure it is indeed going to fit, function, etc.
cjweb11
cjweb11
Houston TX
Thanks for all the help, gave arh a call they confirmed the GMT0734W/C is good to go for the tahoes as well. looks like it's time to spend some more hard earned greenbacks
cjweb11
cjweb11
Houston TX
Unfortunately I havent even placed the order yet... haha
I finally got around to installing the corsa touring on the stock headers in the driveway last weekend, which I am very happy with by themselves, nice low growl at idle and roars when you open it up, hear a slight difference in exhaust sound while driving, but no hollow drone whatsoever, maybe just a placebo effect but i swear i feel a little more get-up-and-go out of the hoe.
I'll follow up as soon as I get the headers done.
For now heres some pics with the catback:
Snacky
cjweb11, did you ever get those headers?
JPeter
