What color?
tx07tahoe
Houston,Tx
I have been thinking about putting LED bulbs in the DRL's. Right now I have the Silverstars with the amber color. I have been told that its hard to see the turn signals when the DRL's are on and want a change.
So what color should I go with?
Or should I try something different or keep them and change the signals?
FYI my tahoe is Silver Birch Metallic and I have 6k HID's in the Low's and Fog's.
Here is a link.
http://www.v-leds.com/DE3175-3175-LED/c122281-1-2/
zach2011
Platinum Member
If I ever go that route, it would be white. Blue or red would get me pulled over. I also thought about purple like Modded did, it looks sick.
Whatever you decide, post pics when you get it. :)
tx07tahoe
tx07tahoe
Houston,Tx
Maybe I should go with white cause the cops around here get bored alot.
Fast55
Ventura County USA
I used the 3157_27_MSMT_W for the DRL's and 3157_20_A for parking light/turn signals. I really like the LED's in the DRL's. The turn/park LED isn't as bright for parking lights but is fine for turn signals. I believe it's more a function of the small reflector area because the 3157_20_R's for the rear signals are really bright. Bad thing is pulling the whole headlight to get to the wiring to add the load resistors. No problem on the rear, but I took the whole bumper cover off to pull the headlights up front and mounted the resistors to the core support on the mounting plates they also sell. I'm now 100% LED, inside and out.
tx07tahoe
tx07tahoe
Houston,Tx
Can you post up some pics please?
Fast55
Ventura County USA
I just got home. I'll get some pics tomorrow. What do you want to see, inside, outside, front, rear?
Fast55
Ventura County USA
Here are the front and rear LED's.
Zed 71
Pacific NW
Fast55 that looks good. Are the rear LED bulbs in the brake lights much brighter that stock?
Fast55
Ventura County USA
Definitely brighter. Not like the G4's, but noticeably brighter than stock bulbs. You need 2 pairs, so it's about $100, but that's still half the cost of the G4's. The reverse lights are really bright. The only thing I think is a waste is the 194 LED's in the side markers. You can't really tell much difference from a stock bulb. I didn't put them in the puddle lights because mine are switched off (I think approach lighting is the setting in the DIC) because of my HID's.
MonteJ
