2006Tahoe2WD
On the drivers side, back, lower part of the engine there are these items I'm not sure of:
A - some sort of plug (water jacket drain or ? oil galley drain)
B - same question as A
C - small manifold/fitting that has nothing connected to it. If I feel on top there is a hole - can't tell if it is threaded or not. From the location I would guess it is associated with the oil system. Maybe a point to hook in an oil cooler but that option was not attached or someone removed it.
Thanks in advance for your expert knowledge. Vehicle = 2006 Tahoe, 5.3L, 2WD
