Weird transmission leak!
robstor
Sent from my Lumia 710 using Tapatalk. So my 04 Yukon Denali has developed a noticeable leak from inspection holes on bell housing. Here's where the weird part comes into the equation. It only leaks when you start it when it's been parked a long time or the transmission is cold. There is a stream coming out both inspection holes and only for 10 or 15 seconds then stops completely. If I park it overnight I look under and no fluid on the ground, and feel inside the bell housing and no signs of fluid.
robstor
robstor
I hope so. It doesn't sound to difficult.
El Capitan
Senior Texas Member
Grapevine, TX
Mine started leaking in the same spot over the weekend, in the shop now let you know whats leaking on mine maybe it'll help.
El Capitan
Senior Texas Member
Grapevine, TX
Mine was the input seal. AER (who I bought my trans from) is replacing the whole trans under warranty.
robstor
robstor
Cool. Glad to hear they are replaced it. I'll have to look into that. Thanks for the input.
CKendrick
