Weird problem with 4th gear
jxw004
So my 2004 tahoe 5.3l has started acting up in 4th gear. It will cruise just fine at 75 but will not hold any speed above that unless I shift it into 3rd. All other gears work fine, it is lifted on 33s but has been this way for a while and it started this a few weeks ago. The torque converter will lock (if you hold the accelerator and lightly press the brake it will unlock and jump up about 500 rpm). I am getting crappy mileage, about 11 on free way. Any ideas on what could be causing this? I have a diablo programer on the way and one of the options is to clean the TCM memory, would this help or no?
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Clearing TCM memory will just erase any codes that are stored and reset all adaptive memory (ie: learned shifting patterns, etc).
BlacktopBandit76
