Water Pump
TnTahoe
TN
My truck is leaking antifreeze but only when it sits up. And I have found that it is seeping out of the water pump. I figure I can just replace the metal gasket and o ring but how would I know if my water pump is going bad??
gcletsos
There is a small hole on the pump where the shaft runs through the housing. If the water is coming out of the hole then the bearings are shot and you need a new pump. That is usually where pumps fail.
NovaRacer
North Carolina
If it's leaking out of the weep hole, and its a cold water leak, it won't stop unless you replace the gasket and o-ring......but IMO, go ahead and replace it anyway....you are going to take it off to replace those parts, right? Might as well put a new, or rebuilt one back on it. That way, if the bearing is going out, you won't have to re-do it again later.
Depending on the miles, go ahead and replace the serp belt also.
My .02
WB
rich5368
Cheyenne, WY
Mine did this. I changed the gaskets and no more leaky leaky. Shoulda gone ahead and changed the pump. I did it 6 months ago and my wife told me she had a puddle in the driveway today so I get to do it again
vsaravia
