23sonthetahoe
- Joined
- Sep 21, 2015
- Posts
- 39
- Reaction score
- 20
Hows it goin,
I did the wp yesterday. As soon as I turned the key apon completion, im hearing a fairly quite squeal that changes pitch randomly. As well, wen I rev it in park the squeal gets a little louder but not by much . Can't here it when truck is moving.
Should I hv dumped fluid into the pump somehow at the upper rad hose or into the pump somehow ? Would fluid not get to the pump if I filled it all the way up top at over flow tank. Did the pump get screwed up cause it started out running dry ?
What about the belt could it be making the.noise if.its not the right amount of tension . It spounds like.its on the outside of accesories location not inside like from a pump.
Peace, James.
Peace, James.
