Water in the door
tx07tahoe
Houston,Tx
So yesturday it rained all day and the streets in the neighborhood I live in flooded. I had to drive in it to get home. It wasnt much just a little above the bottom of the rim. Now I find out I have water that got into the bottom of the passenger drivers side door. I can hear it when I move the door. I only noticed because I went outside and found it draining onto the driveway.
Keanen55
HOUSTON, TX
The same thing is happening with mine too!! Not sure where the leak is and never been too the body shop either!
tx07tahoe
tx07tahoe
Houston,Tx
I havent been to the body shop for the sides but for the rear. I dont think that would cause this. Its a good amount of water that is in there and it is draining at a good rate.
---------- Post added at 12:56 PM ---------- Previous post was at 12:46 PM ----------
Ok Keanen I moved the door back and forth for a minute and it started to drain a little faster.
stevek
Dallas, TX
There is a drain hole under the weather stripping on the bottom of the door I believe, peel back the strip and see if the hole is clogged
moto
