Washer fluid tank leak?
TheBigler
Mobile, Alabama
i got a leak in my washer fluid in tank and i cant figure out how to get the darn thing out any body got some suggestions for me and were i can buy a new one to replace it?
EastTXYukon
Longview, TX
I guess it's just my lucky day. Everyone is posting up their problems, and they just so happen to be the same as mine!
Thanks for all the help for guys like me who are kind of mechanically retarded.
992dr
Eastern N.C.
Good question. Mine has had a leak for years. If I fill it too much it leaks out.
I would like to know the same info.
vehicle year and model please.
I'm thinking its a new 97-99 model, they are located up front under what is beleived to be the second battery tray.
Hah, this is a great site. One problem, noone has answered the question yet, hah.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Here are some basic instruction for 99.
REMOVAL PROCEDURE
Remove the auxiliary battery and battery tray, if equipped.
Remove the two bolts.
Disconnect the hose(s) from the washer pump(s).
Disconnect the electrical connector(s) from the washer pump(s).
Remove the washer solvent container from the vehicle.
INSTALLATION PROCEDURE
Install the washer solvent container on the vehicle.
Connect the electrical connector(s) to the washer pump(s).
Connect the hose(s) to the washer pump(s).
NOTE: Refer to Fastener Notice in Cautions and Notices.
Install the two bolts.
Tighten
Tighten the two bolts to 6 N.m (53 lb in) .
Install the auxiliary battery and battery tray, if equipped.
TheBigler
TheBigler
Mobile, Alabama
thx for the help i'm gunna give this a try this weekend when i get the time you know were i can see any pictures or another forum to look at if i get stuck trying to fix it?
robertdgrant
My wifes 2007 Equinox washer fluid started leaking, Noticed the driver and passenger floors were wet with fluid, Service found the hose in floorboard broken -- they replaced it and no more leak,
jsmith14
Really the best factor to do is to replace it. Make sure it is clean and dry the use plain old silicone and forget it the hole/crack will be completly sealed and repaired as soon as the silicone drys. Just make sure you have it squeezed / pressed into the opening. here are some guide you can use on how to replace a washer tank.
95escahoe
I had a leak on mine and it ended up being the pump that attaches to the bottom of the tank would leak, picked one up threw it on and haven't had any problems since
mfinta
