Want to drop my Tahoe to level.
That's for the pair.
Hold on a second. Now that I look back at that ad it looks like that is per each side so you'd need to get 2 of them. Sorry about that. I needed to reread it to verify. That should be all you need to lower the front of your ride.
thats for each one and im a belltech dealer and beat stylins price all the time.
x2...thanks for hopping in here Tony :waytogo: I was just using Stylin's link for example purposes :High 5:
NORCAL SS
SUV SUSPENSION GURU
no i understand. Stylin just sells parts they have no install experience and just read from a book. I install these kits and back it up with 24/7 support which many here that bought from me like.
Question on those Adjustable struts, Tony. How do you adjust them? Reading on them it states they can be used for a 1" front lift all the way down to a 2" lower. Is there a nut on them or something that brings them down? :think:
2011Tahoe
Wa Coast
just my 2 cents, I installed a set of those struts on a titan to lift it and I was not impressed at all. the kit appears so cheap and struts use spacers under the bottom spring seat to lift them. not sure how they are used to lower but I think the bottom spring seat just sits on a ridge that is built into the strut housing. Sorry Tony, but maybe you can educate me on this a little more to be more satisfied. Thanks.
NORCAL SS
SUV SUSPENSION GURU
if you look at the stock struts you will see there is only a little snap ring holding the lower spring mount. to lower the truck you run no spacers which in turn moves the lower spring perch lower down. Ive used thse struts on trailblazers/f150s/tahoese etc no issues. So you know the belltech ring is much thicker than the snap ring used on the stock gm shocks.
Hodmjstone
