Walmart AGM Battery. Seems to be liquid filled?
Roger08LTZ
Nothing really important here. I just put a new battery in my 08 Tahoe. I've been using and having good luck with Walmart batteries. This time I bought one of their EverStart Platinum AGM batteries. When I was moving it around it appeared to slosh inside like a flooded lead acid battery. I thought AGM's had a gel electrolyte, and no water. It almost feels like I got a Flooded lead acid battery with a AGM sticker on it. Do AGM's have liquid inside? Thanks
rdezs
Supposedly only enough to keep the fiberglass mats between the lead plates wet. If you hear sloshing inside the battery, I would return it. Probably a labeling error by their battery vendor.
j91z28d1
gel is an actual gel cell battery. those exist but not used in cars that I know of. mostly golf carts that are used indoors, since they are sealed.
I don't remember agm sloshing around thou. I've never really tried shaking one around thou.
R
Roger08LTZ
The battery label says "non spillable", so I would expect a gel inside. I'm going to go to a different store and shake a different one to see, then double check mine to make sure I'm not hallucinating then exchange if appropriate. I'm thinking the mislabeled at the factory scenario.
rdezs
Probably 99% of everyone who buys a car battery at Walmart has no clue what the differences are.
Durobans
