Voltage level drops when hit bump in road
gmacc77
VOLTage level drops when hit bump in road level drops
hit bump in road voltage level drops lights dim radio fades need HELP
Thank u
1999 Tahoe z71
G
gmacc77
Voltage level drops when hit bump in road lights dim radio fades small bumps just started about 5 days ago im afraid it will die on me it drop pretty low than back to normal until next bump
tha nks
1999 Tahoe z71
YukonXLPerk
Check all of your ground wires. It could be that you have one loose.
I had a similar issue with my old tahoe. Turned out to be the negative terminal on my battery.
Nothing stays tight forever.
rmodel65
the stud on the back of my alternator is loose on my 97 tahoe the voltage was jumping all around and the battery light was coming on. that is where i found the problem
rmodel65
here is why my voltage wasnt consistent
Cammed 2002_Yukon
