VHT Niteshade issues
Big Motion
Washington, NC
i am trying to black out my drl/parking light. I cleaned them with simple green then sprayed the vht and it looks like it cracked and separated as soon as i sprayed it. i put another level to see if it helped, but it didn't. gonna clean it off and try again, but i need to find out why that happened. simple green maybe?? should i sand the plastic before i spray it?? btw i did tails and 3rd brake light same way with no issues.
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
Wetsand with I drop of dish soap with 1500-2000 grit...it needs something to hold onto
Sent from my SCH-I500 using Tapatalk
gdddup
NJ
wet sand and clean them real good. and give them a final wipe with some prepsol or rubbing alcohol
JKmotorsports
Austin, TX
It was the Simple Green. Like gdddup said above, you have to use something like Prepsol or rubbing alcohol. That will dissolve any oils, wax, etc left on the lens and "soften" the plastic for the paint to adhere better.
briannorris
