Hey I need a bit more help with these vacuum lines but I figured the only way anyone will understand what I need is if I take some pictures so I made a little list of which vacuum lines need to be sorted out still...
I need to figure out where lines number 1, 5, 6 & 7 go. Also need to check if I have the rest of the lines in the correct spot. The diagram above helped but mine seems to have extra lines??
Lines 2,3 & 4 I have looked at another truck to make sure that's where they go but the truck is unaccessible now so I can't go look at it again.
This line starts here
Goes around the throttle body
And ends up on this side leading to nowhere...I have looked around for the length of the line and tried to find a spot for it but can't find anything.
Number 2 goes around the back of the manifold
