Under hood light mod
treehan77
TYF Fiend
Crestview, FL
Will this mod work for the 05 Yukon? Not sure if it'll have the same mounting location etc. has anyone done this or similar? Seems like it'd be an easy and cheap find at junkyard...
Light mod
Whoops, the link requires you are a member there. Won't let me attach the large PDF either, so i guess i;ll have to hope you guys are members over there also
ezdaar
Chat Troll
Redneck central, Aka Houston
Are you saying you want a under hood light?
I make and sell this kit. Its 90% PNP.
All you need to do is drill the hole for the switch and run the wires theough existing conduit.
Once done. Its practically invisible.
Everything is soldered and double heatshrinked. Absolutely no ****** crimp connectors or electrical tape.
My silverado, all my kits but the tahoe below are like this.
Tahoe with a oem hood light.
treehan77
treehan77
TYF Fiend
Crestview, FL
Yep need a light. How much is your kit and where do I buy it? I'm not sure what I'm looking at in the "Tahoe with oem hood light" pic, it looks like it has two lights, but the tahoes I've seen only have one actual light and were pre-2003(?)
TheAutumnWind
Doug has a kickass setup. So much better than the crap OEM light.
Good dude too, I'd buy from him.
blazerjohnny94
da hill
Interested in pricing 03 Tahoe no factory underhood light and are we able to pin this to factory location?
seven9st surfer
Milton, FL
I'm about to build one of these for my 03 Yukon. I'm looking through the pictures, and it looks like you routed the hood-mounted LED strip behind the insulation, but where did you install the pin switch?
ezdaar
Chat Troll
Yea, power wire is behind the insulation and then down through the hood ground wire conduit.
There is no hood pin switch.
I could and would love tp tell ya more. But i am selling these and its my secrets on how i build them.
Its not terribly difficult, so of your smart and take your time. You will figure it out.
So good luck.
seven9st surfer
Milton, FL
Looks pretty slick.
So good luck.
No worries, I understand you're trying to make some money. I think I figured it out, though... Hope mine looks as clean as yours.
Candielaine
