Tune-up
ATL
i didnt pull my tb off to clean it, although you could clean it more thoroughly if you do. but if you do pull it, make sure to have a new gasket on hand
i just used a can of tb cleaner, and old tooth brush and a shop rag. simply spray, brush(while holding throttle blade open), spray again, then wipe with rag. done
B
bikerglasses
anyone have any hints on pulling the wires off the plugs.... I tried 3 different plugs and I can't get the wires off... it's so frustrating, and my hands are killing me from trying to squeeze and wiggle them off....
thanks.
fire730
Louisiana
You are replacing them, right?
Take them loose from the coil pack and them try and twist it off the plug. After it turns some just pull it by the wire.
B
bikerglasses
I'll prob have to use some channel locks or something to pull the boot off the plug...never felt plus so insanely stuck on.
B
bikerglasses
quick question before I do tune-up tomorrow... I can just take off all wires and plugs at same time, I don't need to do 1 at a time...right?
B
bikerglasses
that's what I thought.
sounds good ..just sucks i'll need to use channel locks to pull the wires off...
fire730
Louisiana
You can do them without channel locks.
Do like I said and twist them before you pull them. You will most likely destroy the metal heat shields by using the channel locks. You may destroy the wires but I refuse to change plugs on customers trucks if they dont want to replace the wires even though I can usaually get them off without breaking them by twisting before pulling them.
B
bikerglasses
Just finished and it sucked... almost gave up on passenger rear plug but finally got it.
Wires weren't that bad, but broke about 5 of them and needed to use pliers to get them off.
All and all...glad I don't have to do it again.
Sent from my DROIDX using Tapatalk 2
B
bikerglasses
Sadly my plugs were tight where I needed the ratchet.
All plugs were easy except passenger back. The other annoying part like I mentioned was the wires... but if you do what was suggested above and make sure wire is off plug and pull it should be fine, my problem was twisting them off and making sure it was off plug..they were tight too...that's how I broke a few of the wires.
johnsonwillie199
