Jobi-Wan Kenobi
- Joined
- Aug 27, 2022
- Posts
- 231
- Reaction score
- 306
I did the trucool 40k install over the weekend (yay!). But now I'm wondering if I actually screwed this up. I opted to go with the kit from Glenn's Auto Performance and used their line kit with eliminates the cooler built into the radiator. I found out tonight now that the cooler section built into the radiator is a water to oil cooler and helps to heat the oil in cold climates (Wisconsin winters). So now I'm wondering if I should have kept the factory lines in place instead.
www.glennsautoperformance.com
PTFE Braided Stainless Transmission Line Set - 99-07 GM Truck
Pre-assembled -6AN PTFE braided stainless transmission line set designed for 1999-2007 GM Trucks (Silverado/Sierra/SUV) using the Tru-Cool 40K Transmission Coolers (LPD47391). These offer a bolt on solution that eliminates the need for failure prone rubber line and hose clamps. Rated at well...
