Truck seems slugish...
mhorn0817
maryland
it could be one or the other or both, i swapped on my newer tahoe 20's around the same time i changed my plugs and wires. i used ac delco wires and ac delco oem iridium plugs (part number 41-110, from advance auto parts). i replaced my air filter and cleaned my maf not to long ago. and my throttle body was cleaned a while back as well. my fuel filter has been changed as well in the past. i have intake,exhaust,w4m tune,newer tahoe 20's.
ive been reading up about seafoaming and while most people have had great success the 1 time i used it in my 95 s10 i had a horrible expierence. after the seafrom through the vac port it put on a nice smoke show and when i drove it i could tell the difference right away, a couple days later my truck wouldnt even run because the spark plugs were so fouled out. left me stranded on the side of the road.
anyway just curious your guys thoughts and opinions on what to check,do,etc...this is on a 04 denali with almost 92k miles.
blueflamed03
Oklahoma
any codes? swapping to bigger, larger rims and tires takes away power, and gas mileage.
M
mhorn0817
maryland
nope no codes, i was prety much assuming the tires, but figured there could prob be some other routine thigns i can check and do
Arctic-Rodz
RGV Texas
What size tire/wheel did you have before the 20's and what tire are you running on the 20's?
Also, excuse my lack of knowledge on the topic but, what is Seafoam? Ive heard it around the forum. What does it do, where does it go, purpose?
M
mhorn0817
maryland
stock tire size - 265/70/17
current tire size - 275/55/20
seafoam is a liquid can be poured into gas and oil as well as be sucked into a vaccum port for the motor. basically cleans the carbon deposits inside the motor. makes a pretty cool smoke show as well
blueflamed03
Oklahoma
well its not the drastic tire height, like .3"....Id run a code and see, unless your just noticing the heavier mass of the 20's
M
mhorn0817
maryland
yeah no codes, i guess it just the 20's...i shouldve weighed both just to know...still would like to do some clean up on the truck...whats reccomended?
M
mhorn0817
maryland
no i dont have tires on them anymore, someone was supposed to buy them and didnt want the tires so i took them off and then of course the buyer backs out
gordo
Denver Colorado
what did you gap the spark pluggs to? the previus gap or did u leave the .40 gap that the delcos come with. I just did a tune up on my friend new denali, it 2 was sluggish but we cleaned the throttle body and changed the pluggs with the right gap and the issue was fixed
Ironman1979
Odessa, TX
nope.. i just got a set of plugs for my truck and out of the box they had gaps rainging form .025 to .050.. gap on my truck is supposed to be .035
sparg93
Expedition Tahoe
NJ
The AC Delco premium plugs (i.e. Iridium) do come pregapped...it is recommended however that you check each one prior to install just in case one or more is off.
I just did my tuneup and they were all spot on...but unfortunately it doesn't mean yours
were as accurate.
I'm not sure if your '04 was part of the change, but there was one or more years in the NBS that came out of the factory with one gap settng (i think it was .06) and then GM came out with a release that the truck will run better at .045. I have an OBS so i didn't track the change, but it might be worth investigating for the appropriate changes and then pulling one or all of your plugs to check gap.
However, I would bet those 20's are a bit heavier then what you had and rolling mass can make a difference in accelerating. I would recommend going onto sites that sell the rims/tires you have had and adding up the weights.
Sasquatch
Orange County N.Y.
When i swapped from my stock 16`s 20 inch LTZ wheels i weighed them both.
The stockers were around 71 pounds and the 20`s were 92 pounds. The weight is for one tire and wheel.
With the increased weight and diameter and my yukon having 3:42 gears i felt a difference in off the line acceleration and a slight difference in braking.
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
Seafoam, plugs/&wires.... Clean tb and replace fuel filter???no expert whatsoever but may help with process of elimination
JeffK
