Trouble replacing antenna lead
FrankC
'06 Yukon XL Denali with open coax from antenna base to junction behind glove box. I pulled out the old one with a string attached, but spent hours and still unable to feed anything back trough. Have tried the new coax cable, a stiff wire, soft copper wire, almost anything and can not get anything to feed from the hole in the sheet metal past that air filter behind the glove box. Any YouTube I have been able to find either ignores the difficulty or only mentions that it is difficult. Removing the cover over the dash board makes no difference as it is still impossible to see anything. I'm not sure removing the fender will even help that much.
I'm about to re-route the antenna lead with some extensions across the engine and down through the firewall below the brake pedal, which seems to be about the only place where you can actually get through!
Anybody got any ideas on this??????? Thanks
TallHoe 96 OBS
