I have a 2023 Yukon XL and the transmission seems to hesitate. Took it to the dealer and they said there were some codes going off and they reset them. It ran fine for a week then started again. Anyone else have this problem or know of a fix?
It has 63,000 miles. So there is no recall on this issue. The only thing I can do is to take it to a transmission place and have the valve body replaced?You did not say how many miles are on the vehicle.
The majority of shifting related problems are all valve body related. The GM 10 speed valve bodies are known to have problems. The longer the vehicle is driven with sloppy shifting, the more wear and possible damage to the clutch packs.
I would hope the dealer documented the codes on the repair order, even if they are not on the copy you received, hopefully the tech put the codes on the notes. You may be able to have the Service Advisor get you the technician notes.
I would also suggest getting your own OBDII App. If the SES/CEL/MIL comes on any generic OBDII tool should be able to read and display the codes. There are phone App for $10 or under and you can buy an OBDII interface for around $35 so you can always have a code reader in the vehicle at all times. I one in most of my vehicles.
You may also want to read over this thread to get an idea of what is going on with the GM valve bodies - https://www.tahoeyukonforum.com/thr...peed-valve-body-kit-finally-installed.153898/
How many miles has the poor shifting been happening?We have the 5.3l and 10-speed
The best bet is to have a full diag work-up performed. This starts with pulling up all the DTCs then working them from smallest to largest. Next step is the test drive with live data to verify each condition/drivability symptom by seeing it in the data (examples include excessive shift times, TCC slip during high TCC duty cycle, etc). From there (depending on what the data reveals), follow up component testing should be done, including to the transmission's wiring harness, variable force solenoid set as well as anything else that may have flagged in the data during the test drive.It has 63,000 miles. So there is no recall on this issue. The only thing I can do is to take it to a transmission place and have the valve body replaced?
Around 2,000How many miles has the poor shifting been happening?
My 2024 Tahoe (purchased new last Sept) has throttle lag when in Normal and Sport It makes me nuts. I drive in L9 instead and enjoy V8 power. I think it's the same as "trailer mode" in my old 2015 Suburban.I have a 2023 Yukon XL and the transmission seems to hesitate. Took it to the dealer and they said there were some codes going off and they reset them. It ran fine for a week then started again. Anyone else have this problem or know of a fix?
