Transfer case help
Steve01984
Massachusetts
So I have a 1998 Tahoe sport 2 door. With manual floor shift tcase. I had to get new harness from tcase to front diff actuator but only can find one from older unit that has older style actuator with two plugs on diff. Is there anyone that knows if I can just splice in 4 wires to newer connector and make it work on newer actuator in front and if so could send a schematic.
Moderator
People's Republic of Colorado
See if the diagrams below would help. Verify your vehicle and navigate to the appropriate pages.
exp500
You may have to build a harness with new connectors.
Otherwise try finding a donor at UPullit.
With luck, both ends of connectors are available as repair splces so just add wire to make long enough.
Post pics and info you have about your requirements and more help usually appears.
johnsonwillie199
