Trailer Brake Control Install
Dixonfamily91
Anderson, SC
Howdy gang, I have a trailer brake control to install. Any suggestions on where to mount it? What has worked for you?
Thanks,
Td
Jewel or Jalopy
Portland, ORE
I mounted ours under the dash near my right leg. Its a bit hard to see the display but close enough to reach if I need to manually engage it. I have to lean forward a bit when I set it to see properly.
cowboyzr2
Magnolia, TX
x2. A lot of customers wanted them mounted on the plastic just below the gauge bezel... But I hated drilling holes in it and also having the ugly wiring running up to it. My preference is running a couple of self-tappers into the metal support at the very bottom and mounting it as far right as you can.
The 'ER
Minnesnowta
I made a little bracket and mounted it behind my center console and keeps it low and close to the center which is nice. Just metal that I bent to hold it in place and I pull it out when I don't need it.
nominion
I realize this is an old thread, but I figured I'd contribute in case someone else was looking for ideas. I mounted my brake controller in the center console/arm rest of my 2013 Yukon. I assume this would also work for earlier year models too.
Bill-H
Ohio
PErsonally, i like this option best
01ssreda4
Ive got mine inside the center console on the wall closest to me. Its quick and easy to make an adjustment if needed and I dont have to look at the dang thing the other 99% of times Im not using it. They arent most attractive devices after all.
Screamn03
Vacaville, CA
This is how I mounted mine, I like the idea of the center console too, didn't even consider it.
wiltff
Its too bad nobody make one that's a remote module to mount under the dash. Maybe with a corded or wireless remote for when you need it.
BrentL9900
