Track times?
2 E L O
Omaha, NE
Do not run E85.
Also, running 93 octane will hurt you more than help you. Run the lowest octane possible without pre-ignition or pinging. These Tahoes don't have high enough compression to make 93 octane fuel necessary.
You can get away with 91 for sure...probably even lower would be better...depending on what's offered in your area.
I believe the '07+ 5.3s are 9.9:1 compression ratio, correct? There is absolutely no reason to use 93 octane for only 9.9:1 CR.
UofMZ71
what if you did the BB tune with a 93 octane upgrade? i feel a difference in 87 vs 93 with BB tune, dont know about racing times but mpg and others have improved...
2 E L O
Omaha, NE
There are other factors that can make using a higher octane fuel necessary besides compression. I guess I didn't specify in my last post, but I meant for stock or un-tuned (and I don't consider handhelds to be true "tunes").
With a BB tune, I'm assuming Justin uses more aggressive ignition timing (among other things like better fuel maps, etc.) to increase performance with his 93 octane tunes so then, of course, you would want to use whatever he recommends = 93 octane. Otherwise, you may get some detonation, performance will suffer, and it could damage the internals.
However, just a little run of the mill handheld tuner like my Hypertech or a Bully Dog is not going to be aggressive enough to justify using 93 octane...
emann_01
what track and what time today? I may come watch this for the hell of it....hell maybe get mine on there
wanna run our hoes heads up to see what the mods i have really do?
tx07tahoe
tx07tahoe
Houston,Tx
Ya sounds good hold on I just asked my friend.
---------- Post added at 09:42 AM ---------- Previous post was at 09:40 AM ----------
Ok Baytown and leaving around 8 or 9.
Zed 71
Pacific NW
Hopefully you guys can run together (emann & tx). I would be cool to see the difference in performance with respective mods.
blueflamed03
Oklahoma
I see your point 2ELO, but 93 won't hurt him too drastically, if he was tuned. Most, even the handhelds respectfully adjust timing to where the detonation will come on faster. So I'd run the 93 if possible. It won't kill it like putting in 105 octane, that would be overkill.
David4Jesus
Augusta, Ga
Not to get your hopes up but in the xl with the 5.3 I took a 3000 gt until the governor kicked in, I was suprised but its a 6 banger. Yeah make sure you don't red light and no need to heat them tires up, power brake it a little. It is that time of year again, I'm itching for mid 10s in the SS at the track this year myself.
tx07tahoe
tx07tahoe
Houston,Tx
Ok guys I never posted this video on here due to the fact no Tahoes or yukons are in it. But it has a couple of the trucks that I may run with. In the first one you can hear the red trucks tires catch. Take in mind this is only a two block race.
http://s958.photobucket.com/albums/ae70/tx07tahoe/?action=view&current=100_0317.flv
http://s958.photobucket.com/albums/ae70/tx07tahoe/?action=view&current=100_0316.flv
http://s958.photobucket.com/albums/ae70/tx07tahoe/?action=view&current=100_0318.flv
scvbht
