torsion bars making noise
southernstylen
i lifted my 03 2wd tahoe and bought some tires that were too big and had to run the torsion bars all the way up and when i would make a hard turn( full lock) as you started moving there would be a big thud. i changed to the right size i want and put the torsion bars back down to what i think is close to stock and it still does the same thing. i looked under the truck and it looks like the torsion bar is spinning inside the lower control arm. it seems like maybe once you get the steering in a bind from turning full lock the torsion bar slips in the control arm and then when you straighten back out it comes back to where it was? anyone had this problem or heard anyone with it? oh my lift is 4in spindles and two inch spacers
brucebruce45
i got 4'' spindles and keys on my 2wd hoe an it's never made a noise like that
johnsonwillie199
