Torsion bar slipping?
J444HN
Need a bit of advice please guys.
I have had my alignment done a few times now but the outer edge of my drivers tire is still wearing bad. And it almost feels like the two front wheels are continuously fighting against each other. Measuring the front it seems like even though I've had the torsion bar adjust it is still dropping back down or something is moving and knocking off alignment.
There is no more adjustment left to lift the drivers torsion bar.
Looking at where the T-B goes into the lower control arm, on the passenger side it looks fine and sits straight in...but the drivers side looks like the TB is slipping round inside the control arm? The hex shape isn't sitting straight inside the hex of the control arm.
When I corner right the drivers front seems to be useless and unstable like it's not holding up.
Please help and I apologise for the long post.
Thanks
John
shakedown067
My drivers side T-bar looks like that too. No issues. I'd check your bearings and toe rod ends.
afpj
+1 to what shakedown said.. Alignment might be perfect but if you have worn suspension parts (not just the torsion bars) then alignment won't hold under dynamic load...I.e. Rolling down the road.
J444HN
J444HN
But how would that affect my suspension from sagging on drivers side? I can't get it to level out and it's bottoming out.
What do I need to change to get the adjustment as it seems like the bars just twisting in the LCA and slipping round.
southboundchicken
Jacksonville fl.
More info on your suspension setup pleAse...... I dont think your t bars are your problem they dont "slip" like you think they do and unless you have a million miles on your rig they dont wear out
Tahoe0159
No expert here, but I have never heard of torsion bars wearing out.
Everything else in the front end, yes. Torsion bars, no.
Just one data point, FWIW.
J444HN
J444HN
So if the torsion bars aren't making the front end sag what else can be? I've replaced the air ride stuff with Bilstein about a year ago and the tie rods were done then. What else could cause the front to sag?
TheAutumnWind
Give us your measurements from axle to fender lip L/R
J444HN
J444HN
Left: 21 and a half inches.
Right: 23 inches.
And the left hand side feel like there is not much resistance when cornering, it almost just goes down as it wishes.
Tahoe0159
Have you taken it to a good suspension place and asked them for a diagnosis?
Might be worth it, so you know what parts they think need to be addressed.
Or if you have access to the Factory SM, it has the diagnostic to follow.
For me...I am not a "suspension guy", so I take it to a local place that does my tires and batteries.
They will do suspension diagnosis for free (or cheap) and they have a guy over there who has a lot of experience and he's always given me good advice on front end work. All of my three cars stay in alignment and I have 100k miles + on them. The Tahoe wouldn't hold alignment last year, needed a lower ball joint.
afpj
Even though you change the shocks a year ago, the more common cause would still be the shocks more so than the torsion bar statistically. I wonder if you can swap the shocks left to right and see if it still sags the same way. Interestingly, my ride height front axle to fender lip is 21 inches stock. 22 1/8 in the rear.
mfinta
